Engine management light
Moderators:Popsjag, J44EAG
ianoliver57
Postby ianoliver57 » Sat Jul 27, 2024 5:58 pm
Driving home today, the dreaded engine management light came on. Checked water and oil, all ok. Car stops, starts, idles and runs perfectly normally. There are no error codes or warning messages in the message centre below the speedo. Any ideas? Should it be ok to drive approx 95 miles to the Jag Specialist on Wednesday?
X358 4.2 V8 with 36000 miles.
Ian.
Previously
2004 S Type
2010 XF 3L petrol
2014 XF R-Sport
2010 XKR 5L
2011 XF S
2017 F Type 340
2019 XJ 3L V6
2021 XE R Dynamic P250 S
andypryce
Re: Engine management light
Postby andypryce » Sat Jul 27, 2024 7:43 pm
Should be fine to drive if it is behaving yes. Needs an OBD reader plugging in to get fault codes.
XF Sportbrake 2020 / XK8 1998
ianoliver57
Postby ianoliver57 » Sat Jul 27, 2024 9:06 pm
Thanks Andy. I’ve ordered a reader, due to arrive Tuesday. Never had the EML on before in any car I have owned so was just a bit concerned.
Ian.
Previously
2004 S Type
2010 XF 3L petrol
2014 XF R-Sport
2010 XKR 5L
2011 XF S
2017 F Type 340
2019 XJ 3L V6
BrianG
Postby BrianG » Sun Jul 28, 2024 3:27 pm
Ian,
The simplest things can cause the EML to come on. The first time it happened to me just after I'd filled up with petrol and restarted perfectly OK (why?). Back home I found that the dipstick was not fully seated and the o-ring on the handle was a bit iffy anyway. Re-seating it with a new o-ring caused it to go away. Many of the EML reasons are the result of something being flagged more than twice; single events are usually ignored if they not show-stoppers and only happen once, so you may find when you get your code reader that there a lot of codes set for things which are no longer relevant. The plan then is to clear them and see which ones - if any - come back, before you start getting to involved and expensive.
Good luck!
1969 Triumph Daytona rider
Previous XJs:
X300 3.2 in Spruce / Barley
ianoliver57
Postby ianoliver57 » Sun Jul 28, 2024 3:36 pm
Good advice Brian. The code reader is due to arrive Tuesday and I have to phone Douglas at Prestige Jaguar then anyway to make sure he can take the car on Wednesday To fit yet another two front struts. I’ll tell him what the reader says and he can sort things out.
I’ll post an update when I get the reader.
Ian.
Previously
2004 S Type
2010 XF 3L petrol
2014 XF R-Sport
2010 XKR 5L
2011 XF S
2017 F Type 340
2019 XJ 3L V6
ianoliver57
Postby ianoliver57 » Tue Jul 30, 2024 3:35 pm
OBD arrived today. Only one code noted. PO171 System too lean bank 1. What now? I have cleared the code and the EML.
Ian.
Previously
2004 S Type
2010 XF 3L petrol
2014 XF R-Sport
2010 XKR 5L
2011 XF S
2017 F Type 340
2019 XJ 3L V6
Postby ptjs1 » Tue Jul 30, 2024 4:18 pm
Ian,
I would just drive the car and see what happens. These cars are very sensitive to minor signal fluctuation, voltage integrity etc. If the light suddenly comes back on, then try and remember exactly what the driving conditions were at the point of illumination eg accelerating, decelerating, going uphill etc etc. On my x350 many years ago, it sometimes threw a fault on exactly the same stretch of motorway going uphill. Never happened anywhere else. I became paranoid that it might even be the large radio mast at the side of the road that was causing it! In the end, I just gave up and lived with it, as all the vacuum hoses were fine, no air leaks etc etc.
Fingers crossed, it might never return!
ianoliver57
Postby ianoliver57 » Tue Jul 30, 2024 9:35 pm
95 mile trip tomorrow leaving at 5.30 am to Prestige Jaguar in Paisley. Another two front air struts to be fitted . I’ll keep an eye on the EML. Last time it came on was after a ‘spirited’ overtake….. :roll……fingers crossed.
Ian.
Previously
2004 S Type
2010 XF 3L petrol
2014 XF R-Sport
2010 XKR 5L
2011 XF S
2017 F Type 340
2019 XJ 3L V6
Thixendale
Postby Thixendale » Tue Jul 30, 2024 9:47 pm
Don't overtake anyone then :D :)
Tony
ianoliver57
Postby ianoliver57 » Wed Jul 31, 2024 2:00 pm
Sorry Tony…it had to be done. However, no EML and Prestige happy it was a one off glitch. Back home (another 95 miles) and all good. New air struts on the front. :D :D
Previously
2004 S Type
2010 XF 3L petrol
2014 XF R-Sport
2010 XKR 5L
2011 XF S
2017 F Type 340
2019 XJ 3L V6
andypryce
Postby andypryce » Wed Jul 31, 2024 3:54 pm
Yes, people dread the EML but most of the time it is nothing major. Having said that on my previous X350 eventually had to have 2 new cats at huge expense! Fingers crossed..
