Misfire on 1/3/5/7 - XJR S/C
Posted: Fri Mar 15, 2019 6:16 pm
Hi all -
As an ongoing saga with my XJR continues, I have had all vacuum leaks fixed on the car, fitted new MAP sensor (the one on the throttle body), had new spark plugs, and swapped over the coil packs from one side to the other, but I have a fault remaining which is a misfire all down the one bank, affecting Cylinders 1,3,5,7)
The garage also swapped over the lambda sensors to see if anthing changed but it did not
The garage is unsure where to go now -
Injectors? Cat? Camshaft Position Sensor (Could anyone point out where these are on the 4.2S/C - I guess there are 2, which could be swapped over)
Any experience of this type of fault ?
