X-350 Seminar
Moderators:Popsjag, J44EAG
barrywi
X-350 Seminar
Postby barrywi » Sun Feb 03, 2013 2:26 pm
Thanks for all those who attended the Seminar yesterday. It was great to meet up with those who have emailed or phoned me and to meet the new people who want to buy the car.
I thought David Marks did a splendid job considering that Nigel had to leave under unfortunate circumstances and how he held on to his voice I will never know.
I hope you all got something from the day and were not disappointed. Even though I had been to the previous one I found that it was good to top up my knowledge especially on the complex stuff. Lets also hope that the potential buyers who attended will buy and join the club.
A special thanks also to Dave for his help with a potential magazine item.
robv12
Re: X-350 Seminar
Postby robv12 » Sun Feb 03, 2013 3:00 pm
Barry, yes I echo your thoughts, firstly thanks to Nigel for being there in the very first place and then coming back at the end of the day,especially after such sad news, shows just how committed to the JEC Nigel is, secondly to David Marks for the excellent presentation and his laconic wit of which I seem to bear the brunt of!!, I can handle it, just!!
To the owners who turned, just over 80 in all, with a full range of every model of X350 covered in the car park, an impressive site, I hope some one got some pictures
My own trip home went a bit array, after everyone else had gone I waited at Jaguar with a member whose wife was picking him up, it was a cold night, this chap (sorrry didn't get your name) had no coat, "sit in my car and keep warm" says I, sadly the sat nav said young lady was using, saturday evening traffic and a one way system from hell conspired to a vary late arrival of a clearly very stressed young lady, they were heading out for dinner so I hope the evening improved for them. No problem, I'm a tad late, hey who cares I'm six hours from home, so bag of chips for dinner in the car on the roadside, when the phone rings, Mrs J in a state of panic, her father who is 88 thinks he has had an uninvited "guest" into his flat who has relieved him of his "cash on hand", not a huge sum, but enough to worry the old guy, and to buy 2/3 tyres for a 350, who was in a stare of despair, luckily I was still south of Birmingham, so instaed of M1 north it was M40 south to the M25 just past Heathrow, turn the place upside down and find the cash under the telephone!!, hey ho, head north, home 5.45am Sunday, a LONG day
88 3.6 XJ40 EX JDHT
88 3.6 XJ40 SOV
93 XJ40 XJ12
97 Daimler Double Six
97 XJR 300 Manual EX JDHT
55 X TYPE EST 3.0 SP PREM
56 X150 XK
barrywi
Re: X-350 Seminar
Postby barrywi » Sun Feb 03, 2013 8:04 pm
Rob it seems it was a bad weekend for both you and Nigel. Her below are some notes taken by Jim Walker which may be informative to members who did not attend. I have not checked them yet as I am busy until Wednesday, please edit if there are any mistakes,
Important points picked up from David Marks’ presentation:-
1. There has been a recall on brake pipe corrosion. To check, contact Jaguar and quote the last 6 digits of the VIN. In my case ---G49483.
2. Watch out for bonnet cable release becoming stiff – difficult to repair if it snaps.
3. It is possible for me to change the spark plugs. Just be careful!
4. Check that the air filter has been replaced at the service.
5. Don’t leave key in ignition if doing any maintenance work. Can mess up the software.
6. Look out for ‘surges’ on takeoff. If OK when engine is hot, suspect the torque converter. Reflashing the software can help.
7. After doing a gearbox oil change, reflash engine software then gearbox in that order.
8. Run engine when aligning wheels to get suspension height correct. Check for local wheel aligning specialists at ‘alignmycar.co.uk’.
9. My brakes allow for a wheel size down change. i.e. they are not Brembo brakes. Always reflash software after a wheel size change.
10. Boot will carry a full size spare – but not the 20” wheel
11. Many seemingly unrelated problems are result from a poor battery and/or poor earthing. Always check these first.
12. If there is vibration at around 50/90/120 mph, check propeller shaft and differential.
13. If ‘one shot’ window operation doesn’t work press and hold until window is fully down, and again on raising it.
14. Go to ‘satnav-update.com’ for inexpensive SatNav disc.
15. Wheel nuts should be torqued to 75 lbsft,, no more. Apply a smear of copper grease to threads and backplate to avoid corrosion and damage to wheels.
16. Detailed Jaguar information is available on subscription at TOPIX.
17. Be careful if the petrol filler cover is opened. Easy to brush against it when fueling – and it can snap off.
Jim Walker
almcl
Re: X-350 Seminar
Postby almcl » Mon Feb 04, 2013 12:09 am
Most of that agrees with notes I took but there's a couple of things that didn't come out.
The owner's handbooks are all available free on the Topix site, including the phone handbook, audio, Jaguar voice instructions and accessory fitting instructions.
All 6000+ pages of the workshop manual are available to download from Jagdocs.com http://www.jagdocs.com/index.php?main_p ... cts_id=196 for under a tenner. It is year specific, make sure you get the right one...
It's got all the fault codes and is searchable. The service schedule is available free from the same site.
A code reader which will read ALL the Jaguar codes (not just the generic ones) is available:
http://www.uobd2.com/wholesale/jlr-mong ... rover.html
You need a laptop to plug it in to and setting it up can be fiddly but it gives access to dealer level code setting.
Al McL
SHunt
Re: X-350 Seminar
Postby SHunt » Sun Feb 10, 2013 1:55 pm
Hi all
Just reading the notes taken at the seminar ,unfortunatly I couldnt make it myself due to work and a couple of points were of interest to me . On the subject of 20" wheels my Super V8 is fitted with 20" Cremona wheels including a 20" spare and these are fitted with 255/35 profile tyres and the spare fits in the boot ok , on the subject of brake corrosion i contacted Jaguar via e mail due to my Vin number being G09582 and they confirmed that the work had been completed in August 09 so thanks for info on that .
all the best
Steve
