Driver's door is locked. Unable to open. Currently I need to get into the car through passenger door. Any ideas what I should do?
Thanks, Don
Cannot open the driver's door.
Norbertflyer
Re: Cannot open the driver's door.
Check OBD2 codes first. Could be a fuse. Otherwise, you'll need to take the inside door panel off (easy job) and check the mechanism hasn't come loose, connectors broken, etc. if the actuator is at fault, then a new/replacement one.
