Wiper Parking for Wiper Blade replacement
Posted: Fri May 28, 2021 9:37 pm
by DonA
How do I position the wipers vertically on the windscreen of my X350, so that I could replace the wiper blades.
Thank you. Don Anthony
Re: Wiper Parking for Wiper Blade replacement
Posted: Sat May 29, 2021 8:08 am
by BrianG
There is no way to position the wiper blades vertically. However you should be able to lift each blade sufficiently clear of the glass to change the blade. How difficult this is depends: If you have bought holders complete with blades, press the plastic clip and slide the complete assembly out of the loop in the end of the wiper arm - watch you don't let the spring wack the bare end of the arm on the windscreen glass.Insertion of the new blade holder is a bit fiddly to thread the arm end through the right way round the first time you do it.
If you have just bought "refill" rubbers, these have to be threaded through the several U-shaped hooks on the arm. I find its best to do this by removing the holder and working off the car, as getting the old rubbers out needs pliers to crush the old retainer clip so that the blade can be slid out. Threading the new rubber in, the trick is to do this from the correct end so that the retainer clip goes in last and is clicked home. Fit the refilled blade back as you would a ready-made complete assembly.
Posted: Sat May 29, 2021 4:08 pm
by DonA
Thanks Brian.
I purchased Bosch Aero Twin AR608S. Struggling to fit the blade. Just cannot get the U shape hook, to register in the new blade's slot.
Posted: Sun May 30, 2021 11:03 am
by PaulGover
They should "just work" - I fitted some, and much prefer them to the original Jaguar ones with a nasty aerofoil thingy. I vaguely remember thinking fitting them was a bit like solving one of those bent wire puzzles :-)
Posted: Sun May 30, 2021 1:23 pm
by ptjs1
Turn on the ignition, press the wash-wipe to ensure you have a bit of moisture to avoid damaging the blades, and just cut the ignition when the blades are in the right part of their sweep for you to change them.
Posted: Sun May 30, 2021 4:50 pm
by BrianG
Sorry, NO. That does NOT work - at least on my 2006 X350 (from memory I don't think that worked on my X308 either). They always will self-park after the ignition is turned off.
Posted: Sun May 30, 2021 6:00 pm
by DonA
Did not work for me either.
Posted: Sun May 30, 2021 6:15 pm
by ptjs1
Ok Guys,
Apols for that! My x350, sold some years ago must have had a self-park fault as I can remember changing my blades in that way as it's a bit awkward to change them in the park position, as we know. I wonder if just cutting the power (fuse or battery) would defeat the self-park?
Posted: Sun May 30, 2021 8:58 pm
by DonA
There are two slots, which slot should I use.
Slot A - Insufficient depth to fully insert U shape end of wiper arm
Slot B - The depth looks ok. But it was so difficult/tight to insert the wiper arm, that piece just snapped.
Posted: Sun May 30, 2021 9:54 pm
by Andy P
Hi DonA,
Here's a video of installation which might help:
https://www.bing.com/videos/search?q=Bo ... ORM=VDRVRV
Hope it hels a bit.
Take care.
Andy :D .
Posted: Wed Jun 02, 2021 7:13 pm
by DonA
All sorted out.
Thank you very much for all your comments and advice.
