Gentlemen...please welcome the new J44EAG.
Moderators:Popsjag, J44EAG
Re: Gentlemen...please welcome the new J44EAG.
Postby J44EAG » Thu Oct 01, 2015 12:04 pm
Mikes First Law says if it can be corroded and break off, then it probably will do.
Mikes Second Law says if just one job is envisaged, then it will turn out to be at least three.
Mikes Third Law says that if one hour is needed, then realistically five is probably a better estimate.
Sods Law states that if it can go wrong it will.
Murphys Law states that if it can be fitted backwards, then that is a certainty.
Suppliers Law states the part will be right first time but, six attempts will be required to source.
Suppliers Second Law says the part is in stock locally but when you go to collect it, it isn`t.
Producers Laws states that update kits are available but not readily publicised. Its a trade secret.
Planning these jobs should be done in advance of the work and as far as is possible all parts, tools and research should be done before getting the spanners out. Small parts and fixings need to be carefully stored in seal topped containers to avoid loss or accidental tipping onto a gravel hard standing. Our car park has such a surface and I learned very quickly the perils of working in such an environment.
A few pics now of yesterdays work in progress.
The suction unit I use to salvage and evacuate coolant prior to dismantling cooling system components. This one is a Draper product sourced from ebay. Very useful indeed.
The new modified fixed idler pulley and minimally revised mounting bracket. Note the V-ribs on the running surface and upstand lips to avoid a belt being thrown off in service. The lower large pulley is at the bottom of the image with the new modified pulley at centre with the new small gold coloured supercharger pulley at the top.
This shot shows the rear of the moving belt tensioner unit with the new unit to the bottom right of the picture. Note the two mounting lugs. The old unit is to the upper left and the remains of the broken lug together with just one lug remaining.
Further pictures in the post below. Site volume restricts further image loading on this post.
Postby J44EAG » Thu Oct 01, 2015 12:39 pm
To continue....
This shot shows the moving tensioner mounting which is shared with the alternator bracket. To the bottom left of the picture can be seen the remains of the lug which parted company from the tensioner base when the old tensioner was removed. A right angle drill was needed to remove the remains of the mounting lug from the bracket. Late edit, this image has somehow located to the foot of this post. Scroll to the foot to view image.
This shot further shows the moving tensioner and the mounting lug arrangement. The rear face of the new unit was lightly coated with grease to avoid future removal difficulties.
Finally, the complete belt and pulley installation with the new double sided serpentine belt which has both sides having longitudinal ribbing incorporated into running surfaces. It is appreciably thicker than the old style flat backed belt. Note in the bottom left of the picture the hose with the plastic fitting which is the header tank bottom outlet connection. Note also the silver spring retaining clip which must be removed from left to right with long nosed pliers. When removing the clip ensure you do not drop it! Disconnect this fitting and remove the tank. Immediately replace the spring clip into the connector to avoid loss. Press fit the connector back onto the tank when you rebuild. An audible "click" should be heard as the clip engages with a slot on the header tank outlet. No "click" heard means the connector is not fully home and a massive leak will occur if this connector is not properly in place.
Thats it for the time being.
robv12
Postby robv12 » Thu Oct 01, 2015 3:47 pm
Mike, as always great pics, been there with XJR belts, pulleys, water pumps, header tanks and the damn clip for the header tank hose, easy to get at on all cars except the R, I always keep some in stock, as , yep, you guessed it, the clip is only available as part of the hose, so EuroJag keep a few for me each time I run out!!
don't even start me on today job, X Type headlight adjusters
88 3.6 XJ40 EX JDHT
88 3.6 XJ40 SOV
93 XJ40 XJ12
97 Daimler Double Six
97 XJR 300 Manual EX JDHT
55 X TYPE EST 3.0 SP PREM
56 X150 XK
Postby J44EAG » Thu Oct 01, 2015 8:29 pm
Rather late on parade, Mr J. Like the dust cart after the Lord Mayors Show. Too little and too late! If only you had told me sooner!!
Right. Next project then. What will it be? I need something to do.
Brake pads in stock so I could do those as no further expenditure needed. I could also pack up the ride height sensors whilst I`m down there. A 5mm shim under each sensor mount will drop the car 25mm. Saves going to the control module and adding 25mm to the factory setting via the WDS. I can also take the shims out again if I don`t like the set up. Lowering will reduce body roll a tad. It is quite marked after driving the lowered S-type. Yes it can be done and won`t ruin anything. Seeing this video shows the roll that is present in these cars as standard. Don`t worry ,Barry. I can fix it!
https://www.youtube.com/watch?v=NsGPE-5MVWc
I`ll wait until the S-type is sold before getting the gear box oil changed. Funds have taken a hammering recently.The same with taking a trip to Wokingham to see Tom Lenthall and have him reflash the powertrain ecu.
I could polish the car and hoover it out. No need really because is already sparkles.
barrywi
Postby barrywi » Thu Oct 01, 2015 10:49 pm
Dont forget your earth, sorry ground points, no major expenses there unless they break when you remove them. Dont forget the ones in the boot. Do a photo sequence for the magazine if you can.
barrywi
Postby barrywi » Thu Oct 01, 2015 10:57 pm
Re the video, they only roll like that if you drive like Tiff Noodles. As a Jaguar driver I feel an obligation to maintain a certain amount of decorum on Her Majesty's highways around corners.
Postby ptjs1 » Fri Oct 02, 2015 8:59 am
Get the gearbox done, Mike! That's got to be more important than the pulley, which is just getting more power out of an already quick car.
Don't put it off any longer!
Postby J44EAG » Fri Oct 02, 2015 6:31 pm
The XJR is not being used much presently as I am preferring to put the miles on the S-type until sold. Might as well wear that one out rather than the XJR.
Our Region has a good relationship with Alan Priddy at Express Gearbox in Portsmouth. We had a lecture from him on one occasion. He is retained by the MoD as a transmission consultant and also by ZF to whom he inputs on design improvements. He is quite a character. He runs a family business reconditioning and repairing transmissions and has an excellent reputation. His daughter, Daniele was most helpful this morning when I said I wanted a full gearbox flush, refill and service. The quote is £342 including a new genuine OE sump/filter, the correct oil and VAT. I`ve asked to take pictures for a magazine article for future publication. I now need a replenishment of funds following recent activities so this work can be carried out once the S-type has been sold. There is no rush as the S-type is taking the strain at the moment.
In the meantime I`ve been at it again today cleaning up very minor corrosion on the front ground connections. Most of the corrosion was on the thread stud itself and the the bonding points on the front of the car were found clear, clean and dry. The only corrosion other than the threaded stud was on the outside non important edges of the ring connector lugs. I cleaned it all up applied a film of Vasaline to the parts and reassembled. A little more Vasaline was applied over the finished connections. No point in putting loads of it on as it would melt and just drip off.
Rather more disappointing is the complete breakdown of the galvanised or other plating applied to the six steel bolts which hold the upper plastic radiator support brackets to the front aluminium cross member. The bolt heads and washers together with the bolt threads were a rusty eyesore. These six bolts howled at me every time I removed the large plastic slam panel cover. Had Duralac been applied to those bolts as an insulator when the car was first assembled the bolt pacification would have survived intact. Not having new bolts to hand, I removed them all, cleaned them up in the workshop, doused them in Jenolite to help kill micro corrosion, primed and painted. Having let the paint dry, I applied Vasaline rather than copper grease and reassembled. I`ll get some new bolts in due course and some more Duralac. A tube of that substance will be useful on this car. A marine chandlery or ebay is a good place to get this material. Wear rubber gloves when using. It has a barium content. The rear end ground points will be attended to tomorrow.
As found.
After cleaning up, Jenolite and repainting.
Only a half day on these matters as other things to do.
I can`t help feeling the Cumbrian mountains have a much slower pace of life than down in the deep South. Here the pace is much faster and we need a rally spec car to go to get the curry and chips. This very subject will be covered in my latest book which includes a chapter on collecting domestic supplies. The book is entitled, "Sideways on opposite lock at full throttle when going to Tesco`s". I`ve reserved the first copy for our Barry.
barrywi
Postby barrywi » Sat Oct 03, 2015 12:00 pm
Yes Mike we have sheep carrying red flags in front of every car up here, though most people drive tractors and you do not argue with them! We now get our ASDA food delivered to avoid the 30 mile round trip and the turgid trudge around drafty aisles.
Re corrosion on the 350 I refer you back to one of my early magazine items about getting underneath and sorting out those annoying rusty nuts and bolts on the car. Whatever happened to stainless steel?
Postby J44EAG » Sat Oct 03, 2015 3:43 pm
I would resist the temptation to use stainless fastenings. They are rather more noble a metal than the mild steel that is fitted as standard. You could find that it is then the ali that rots rather than the mild steel. Then you could have to employ the services of an ali welder.....
The problem we appear to have is the quality of the passive plating on the mild steel fasteners and fixings. If replacement is necessary I would be looking to the industrial fastenings market to source replacements rather than perhaps fitting OE Jaguar spares. However even using OE replacement fastenings are still an option but with an improved installation technique being employed. ie use of an electrolytic isolator zinc chromate paste such as Duralac. This material is the stuff to use when fitting two dissimilar metals together and isolates those differing metallic compounds with the paste acting as a barrier to free electron flow.
One must remember what we perhaps learned at school in the form of The Periodic Register. High nobility pure metals such as gold are at the top of the Register and in this case is the material least likely to corrode. This is known as a cathode. At the bottom of the Register are the least noble metals such as zinc and magnesium. Such materials are classed as an anode.
The cathode is a "giver" and the anode, a "taker". When a giver and a taker are in contact with each other, a small electrical current will flow from the cathode to the anode. Over a period of time (especially if an electrolyte solution is added to the situation, ie salt laden water) that electron flow will begin to eat away at the least noble anodic metal with an added vengence.
If the least noble metal in our fixings scenario is mild steel with a zinc plated sacrificial external protective plating employed, over a period of time, the zinc plate will be eroded leaving the then unprotected steel open to the destructive effects of the atmospheric environment. A damp or wet location and oxidisation will combine to cause corrosion.This is when in the case of steel, left untreated and protected, the steel begins to revert to its natural organic base material which is commonly known as iron oxide. Most people simply call it "rust"!
We can control dissimilar metal corrosion by choosing higher quality plated fastenings and by using an electrolytic isolating compound as described above. One has to accept that the plating on nuts and bolts does not last for ever and that in many cases involving ageing cars and machinery, one might find the easiest and quickest answer to corroded materials is simply to change tired components with new items that may be better provided with an improved level of zinc or other plating. Nothing lasts for ever and that includes our goodselves. Left to nature we will essentially revert to carbon, water and in some instances, stale beer.....
In the marine industry, through small boat hull fittings that may be made of bronze are protected by connection to a zinc anode which is fixed to the under water section of a vessels hull. Connecting those bronze fittings via in hull bonding cables ensures that the fittings act as a cathode and electron flow moves to the sacrificial anode which is of slightly less a noble metal and which becomes eaten away in preference to all other underwater fittings. This is crucial to ensure that a vessels skin fittings remain intact and avoid the vessel sinking as a consequence of those fittings being eaten away. The sacrificial protection material is a lump of expendable zinc anode. Go to the MG Duff site for more details on marine galvanic protection.
Perhaps we can learn from this and come up with an answer to our corrosion issues? I would suggest we all attach a length of wire to the chassis of our vehicles and connect it to a lump of zinc to act as an anode in true marine fashion. This could be stored in the boot of the car and used when parking up. All one would have to do is park alongside a large puddle in a car park and chuck the stored anode into the water! That would give a longer life to the plated fixings and fastenings on our cars!!!!
I`ve been on a continued corrosion control session today with the X350R. Having carried out minor work to my front ground connections yesterday, I continued my inspection and reviewed those connections in the boot of the car. I found perfect and uncorroded connections on my MY04 car. The installation is as if it left the factory and no remedial work has been required. I am certain this car has never had a boot leak and has generally been very well stored and maintained. See these images.
Off side rear connections near the battery in as new condition.
The same with the near side rear.
The 350 is a big car with a shallow storage area beneath the boot floor. What space there is has been gobbled by my basic "on the road" survival kit. This consists of:-
High visibility jacket in packet.
Pack of jump leads.
One 12v emergency tyre inflation pump.
One can of expanding tyre inflation gunge for extreme tyre inflation needs.
One small 12v vacuum cleaner.
One K&N fliter cleaning kit.
2.5 litre plastic container of engine oil.
2.5 litre plastic container of concentrate antifreeze, (Orange/pink for ali engines)
2.5 litre plastic container of water.
Half a litre of DOT 4 brake fluid.
One half shreded emergency supercharger belt!
One complete set of brake pads soon to be fitted to the car.
One coolant temperature sensor.
One decent quality wheel nut remover breaker bar with 19mm deep socket for wheel nuts.
Two spare wheel nuts and security coded locking wheel nut socket.
Cheap and nasty Jaguar scissor action jack with screw thread coated in copper anti seize grease.
Wheel chock and space saver/ditch finder spare wheel.
One roll of double sided self adhesive tape.
One small container of acetone.
One small pack of grease removing hand wipes.
Six nitrile protective gloves.
To be added. (In the S-type I would also carry a spare header tank and a used water pump!)
Small pack of metric spanners.
Spare side light, number plate, stop and tail, indicator bulbs.
Warning triangle.
Power steering fluid.
A decent first aid kit of my own specification which will include bandages and scissors, sticky plasters, antiseptic, surgical alcohol, gloves and cleaning wipes.
Old style Jaguar supplied flat cased tool kit.
I need to add some decent "around boot" periphery storage panniers. I`m not that happy having small storage boxes floating around. No wonder it was said that a Jaguar owner always had his luggage sent on ahead!
Postby J44EAG » Sun Oct 04, 2015 10:07 am
This car has settled down nicely after a couple of weeks ownership, some TLC and a couple of modifications. It has been well worth the effort involved.
Following the fitting of a small supercharger pulley mod and then a complete rework of the belt tensioner system, the previous belt throwing antics currently appear to be a thing of the past. With some forty miles of use now on the car following modification and several quick hard applications of throttle and highish revs, matters would now appear to be all good. Changing out the smooth surfaced, shoulder-less fixed idler pulley in favour of a ribbed and shouldered pulley together with a double rib surfaced drive belt and a new automatic tensioner now appears to have this issue under full control.
I`d perhaps suggest other 35OR/XKR, XFR and STR owners inspect their cars supercharger belt components and at least fit the Jaguar produced modified ribbed and shouldered pulley and shorten the existing mounting bracket bearing location by 0.8mm to make the tensioner system a little more reliable and secure. Reworking that mounting bracket would make it identical in dimensions to the modified new fixed bracket that Jaguar also supply. (Save a few pounds by doing so) Fitting a new automatic tensioner unit in addition may not perhaps be necessary. I did fit a new automatic tensioner but I`m not convinced this is any different from the earlier part. The technician I spoke to at Harwods in Chichester did tell me that he had seen issues of belt throwing even with 4.2 litre supercharged cars fitted with a standard sized supercharger pulley. So there would appear to be a design deficiency with the early fixed idler pulley design and updating would generally appear to be a good idea.
My car has 78k miles now covered and inevitably and as expected, a few very small niggles were present when purchased. The drivers power fold mirror was semi seized, slight corrosion was noted on the front grounding points, the parking sensor system was playing up and there was a slight and occasional reluctance for the gear shift to come out of "park" on start up. Other than that, the remaining systems on the car function perfectly.
Cleaning up the front ground points appears to have been productive. The front and rear parking system now works perfectly following the clean up session. No more automatic switching off of the system with a loud bleep when a fault was detected or a permanent bleep for the time reverse gear was selected. One good fix therefore achieved with no financial outlay being required. As Paul and Barry have said, the condition of those front ground points is most important. Cleaning up only takes a few minutes and reassembly in clean condition with a light smear of Vasaline on the parts is well worth the effort. Perhaps the first place to look if your parking sensors are acting up. I found my rear boot located ground points to be in pristine condition and no further work was necessary there.
As regards the reluctance of the gear shift to leave the park position, switching the engine off and restarting could be immediately effective. Apparently some selector strip out, greasing and adjustment had taken place just before I bought the car. However a slight issue was still present and I suspected either a brake switch adjustment issue or just simply a lack of regular use by the previous owner. In my hands the car has been used a little more frequently and the problem has gradually disappeared to the point there no longer seems to be a problem. Cleaning up the front grounding points may also have helped. Who knows.
The drivers power fold issue is now also seemingly resolved if only perhaps on a temporary basis. Paul has experience of power fold seizure due to the internal mechanism being at serious risk of internal ali corrosion. Stripping down the mirror unit will often reveal a massive amount of internal aluminium oxide corrosion and seized components. Certainly my mirror would not fold forward due to seizure. With Paul on the other end of the phone, I managed to carefully persuade the mirror to move forward and exercised it a few times. Injecting releasing fluid into the gap between the mirror cowl and the base mount together with more manual exercise applied by key fob double locking (Two presses on key fob lock button) has gone a long way to restoring full operation. However a clear out of internal corrosion really needs to be done but in the short term this power fold unit is now working well again. Paul said "I bet it stops again in a week"! He is probably right. He is right about most things! Thanks for the tips, Paul.
I spent half an hour yesterday sat in the car playing with all the knobs and whistles. Initially the multitude of electronic systems are a bit daunting. The only way to deal with that is to play with everything until matters become a bit more intuitive. The fog of lack of knowledge is now clearing and operation of the internal car facilities is becoming much easier to understand and use. Its a bit like changing a mobile phone to an alternative type. All it takes is repeated practice until you eventually get the idea.
So what are my impression of the car now I`ve owned it for a couple of weeks? Short answer, great. No grumbles or groans at all. Certainly more complex than the old early model S-type I`ve hacked around in for ten years. Vastly more modern, comfortable and refined s you would expect from a later generation of design. Physically bigger in width and length with much larger accommodation. Better seats allowing great comfort and the ability to adjust pedal position and obtain the leg room I need.
The car has a limousine ride which is well controlled and cosseting. The engine feels long stroked and of much larger in capacity even at parking speeds than the S-type. Excellent development work is evident. The car feels much larger and slightly ponderous in small spaces. That matters little. On the move, the silence is golden after living with the manic tuned circuit car that the S-type became. Both good fun but very different.
People have said the 350 is the best car Jaguar ever built. Clarkson said no other car on this World does every thing so well. I`d say you would have to buy a Rolls or a Bentley to get better. In all respects is is a magnificent masterpiece and believe me when I say i`m never easily convinced about anything. But I am totally smitten with this car. I urge you...GO BUY ONE! Or do as our Chairman does...buy several!!
Mine will be a keeper which is in grade A condition. I`ll get the gearbox oil changed shortly and have Tom Lenthall tweak the ecu to get the best from the supercharger conversion. That`s all that is now needed to have me completely satisfied.
Without doubt the best car I`ve ever owned and at the price of a mouldy old second hand Vauxhall! Its a massive bang for the bucks paid.
Postby ptjs1 » Sun Oct 04, 2015 1:59 pm
Mike,
Good to hear that you've done the first pass through the car and improved some things (but get that gearbox done, pronto!) And whilst you have been complimentary about me, we all know that I'm not usually right but sadly it doesn't stop me having an opinion!
Would be good for you to start some new threads on the BB with the next phases of enhancement, maybe the Bluetooth install and I'm so looking forward to see if you can change a headlight bulb with the bumper still intact! It is possible, but not my favourite job! If you haven't got Bi-xenons, get some Philips Xtreme +130 bulbs in there.
Postby J44EAG » Sun Oct 04, 2015 6:43 pm
Bi-xenons present and something that was on my requirement sheet as essential spec when I was looking for the car.
When I spoke to Paul last weekend he mentioned a small mod to the air box internals that I had previously read about but not filed in my mind for forthcoming action. However with Paul`s prod and having tripped over the matter again, I took some action just now. This also prompted me to do another second slight but very useful mod to that air box which greatly helps with filter removal and replacement.
The first mod was to once again remove the air box lid together with the new K&N air filter. The mod entailed removing two small baffle sections from the bottom of the air box floor. The first so called baffle stands up about an inch high and is very close to the cold air intake which feeds the air box body. This presents a major obstruction to incoming air causing turbulence and disrupted flow within the air box itself. There is also another smaller baffle which again is less than desirable. I consider those two baffles greatly upset charge air in transit and indeed the evidence is there to see on the old paper filter element. Looking at the filthy paper filter element I removed from the filter box the other day, I note there is vastly more muck clinging to the paper element at one end than there is at the other. Air distribution has perhaps not been particularly uniform across the surface of the air filter. A mod therefore had to be done or sleepless nights would occur and I would never be happy.
Air and airflow is an exacting science and is at the root of successful engine tuning. Hence the need for porting and polishing of cylinder heads and inlet and exhaust tracts and other prime parts within an engine. That regime is obsessive when it comes to removal of obstructions. The slightest resistance to air flow is removed as part of that process. The obstructions in the XJR ( seen them in other Jaguar air boxes also both on S/C and N/A models) air box have been noted by other Jaguar engine tweakers on a couple of other web sites. Following their lead, I cut away those obstructions in the hope of a slight increase in air flow and increased internal engine volumetric efficiency. It may not be much of an increase but every little helps. Little plus a little plus a bit more mounts up and gains that can become significant in the overall picture. Every little really does count. Net effect noticed is a slightly quicker low throttle response at low revs when pulling away from standstill. That`s where grunt is at its most useful....low down in the rev range.
The second mod to the air box is one that can be done to other Jaguar models as I`ve previously seen the same detail. It is the same detail whether the car is naturally aspirated, super charged or petrol or diesel. If you do your own servicing and have struggled to remove the TOP section of the air box ABOVE the filter, this can be a tear jerker. Four or five horizontal flat tags stick out from the lower air box. In theory the TOP air box cover which has moulded slots in it, should slide over the flat tags. This is what causes difficulties when removing or refitting the TOP part.
There are two "rogue" tags which are NOT just flat. They are in fact a horizontal ¬ shape! The apparent forward and aft two tags are not flat but flat with a downward hook!!! That hook arrangement is what makes it so hard to remove the TOP air box section and why many service people decide to ignore a filter change. Its a pile of aggravation! There is a simple fix done with a small hack saw blade and will take five minutes. Cut off the down stand hook on the two rogue tags. Job done. Now you CAN easily remove the air box top without loosing your temper, breaking parts off the car or cursing Sir Williams father. This mod will not affect the ability of the top and bottom sections to seal on a new air filter. The mod is pure joy and ecstasy!! Air filter maintenance made easy. If you go to your car and feel for those tags, usually located underneath the MAF sensor tube on the left side of the lower air box section, you can feel the flat tags and also the hooked ones. Then you will best understand why this filter box and servicing can be such a pain to carry out. I`ve done this to my XJR and S-type now and filter removal and replacement is now a cinch.
barrywi
Postby barrywi » Thu Oct 08, 2015 11:38 pm
I can see now why Mike needs all that extra performance!
With almost all,of Halfords stock in there I am surprised you have any room left for the blow up Barbie!
Postby J44EAG » Fri Oct 09, 2015 12:09 pm
Barbi will be filled with helium to save weight. Important to think outside the box. Barry. Far be it for me to suggest you try it yourself....save fuel!
Engineering is a precise science often producing surprising results occasionally but not often for very little outlay. Here at Fred Flintstone Motors a further gas flow modification has been actioned and now tested for over a week. The result has been out of proportion to the amount invested or time taken to achieve. The cost was one pound at the local Pound shop. Reading some of the American Jaguar sites again lead to me following an idea through. These American tuner chappies are not adverse to experimentation or to developing an idea. We Brits used to be ace tuners and modifiers but sadly the art seems to have slipped into a backwater. What the Americans have done is to apply basic gas flowing techniques to the XJR inlet trunking to decrease resistance to air flow and cut down on inlet tract turbulence. Both are power and torque sapping issues. The more air that an engine can be made to consume or be provided with when balanced with appropriate fuel flow changes will help towards an easier running engine, more power and torque together with less throttle use and a consequential reduced fuel consumption. Increased volumetric efficiency results and the car needs less throttle pedal inputs to keep it moving. Doing this modification to my car has resulted in a fuel saving at 56mph of 1.4 mpg shown on the instant consumption facility on the computer display.
It is not unknown for tuners to remove a restrictive exhaust or inlet pipe and substitute with an improved design, usually custom made from stainless steel tube with suitable end fitting adaptors. That is one way of doing it. Then there is an economy method which I have trialled and found very satisfactory in service to date. I`ve not mentioned the idea before because I needed to prove it worked and was devoid of any potential issues. The idea is somewhat crude but very effective. Here is the background scene.
Superchargers are notoriously noisy when producing boost. The whine is distinctive and seen by some to be intrusive. Others like the idea of loud supercharger whine. Each to his own preference. In the X350R the noise is very subdued by design. So how do you make produce extra low speed increased volumetric efficiency, all be it with some unavoidable slight increase in supercharger noise volume?
The answer is quite simple. In the case of the 350R, the XFR, STR and the XKR, Jaguar engineers built a noise attenuation (control) system into the inlet tract pipe upstream of the airflow meter housing and before the large aluminium plenum chamber immediately downstream of the throttle body. Moulded into the large plastic inlet pipe are six attenuation blank ended, open hollow tube type boxes which are tuned for noise reduction. The downside is that the inlet charge air flowing past the ends of the tubes creates turbulence, loss of power and causes a slightly sluggish throttle response when for instance about to exit a side road or entering a fast moving roundabout. This manifests as a rather disconcerting if small lag in power being instantly available in those situations. I found that a little disconcerting and frustrating. It rather spoilt the car. I knew an improvement could be made, so I set out to understand the issue, consider options and decide how I could best engineer a solution.
This then is what I did having read up on the subject and then copied the American tuners ideas into my XJR inlet manifold trunking. The method seals up the attenuator tubes, eradicates turbulence and provides a more immediate throttle response. In doing so there has been only a very slight increase in supercharger whine following the modification. Externally there is no change in appearance to standard. The mod is purely internal.
I removed the inlet trunking pipe from the car and thoroughly cleaned the internal pipe and attenuator tubes with acetone on a rag. I let the solvents flash off. I then filled just one accessible tube with expanding polyurethane foam and set the trunking aside for half an hour. Excess foam spewed from the tube as it expanded. When cured, I trimmed off the excess with a hacksaw blade and finished off with a sharp knife blade and fine sand paper. The foam was blended into the inlet tube to provide a form of gas flowing improvement. That being successful, I repeated the technique on the other five pipes on the inlet pipe. The foam is very sticky stuff when still un-cured but when cured is a permanent solid mass which has adhered well to the plastic of the inlet tube. Shaping of the tubes helps to ensure the foam cannot be sucked out of the pipe in service. If unsuccessful as an experiment it could however be removed and dissolved by pouring acetone onto the foam at which point the inlet pipe could be restored to its former specification. Effectively I have produced a poor mans version of a bespoke made stainless steel inlet pipe but retained the attenuator pipes for renewed use at a later date if I wanted to revert the pipe back to standard. I can hear the howls of protest already!
Having then blown and washed out all the resulting detritus from the pipe, it was fitted back onto the car. On test for the past week and stripped this morning for internal examination, the foam is exactly as I installed it having not moved or broken up. It remains totally secure. On the road the car is much more responsive and the slight hesitancy to move when pulling out of a junction is vastly improved. It makes the car much easier to drive slowly and acceleration is more linear. Disbelieve me if you wish! Some people probably will!! The proof is in the eating. If you wish to incorporate this mod on your own car, that is your decision and risk. I can only recount what I have done as a non standard modification and which I have found very good to date.
