Gentlemen...please welcome the new J44EAG.
Moderators:Popsjag, J44EAG
PTR200Jag
Re: Gentlemen...please welcome the new J44EAG.
Postby PTR200Jag » Sun Sep 27, 2015 4:45 pm
Forget the rugby. The ball is not even a good shape.....nor is my super dooper pulley drive belt any more!
A boot full of throttle this morning had the original 78k mile belt which was looking a bit worn on the ribs off the pulley.
The last serpentine belt I replaced on J44 was at 80k miles. It was a tad longer in length than the replacement. So it is worth noting that these belts do stretch after prolonged service and this XJR was fitted with an aged belt. Replacement was bound to have been needed in the near future. I just got there a bit earlier than anticipated.
You mean you put a new,smaller, pulley on, noticed the belt was worn and didn't put a new belt on :lol: ??? :roll:
Like the stories though! keep 'em coming !
XK8 MY2002
Postby J44EAG » Sun Sep 27, 2015 6:06 pm
I certainly did put the used belt back on again. You see, I spent just over £9500 last week and I was attempting not to spend £9526! The belt seemed in reasonable enough condition to get a couple of thousand miles more out of it in the light I`ve seen these belts last well over 80K miles.
I am guilty as sin of attempting to save £26 in a tight fisted attempt to be able to eat and drink that money! Even Martec on the S-type BB couldn`t achieve this degree of meanness. Those who understand might consider me worthy of friendly financial assistance and PM me to obtain my bank account number. Like Slough, the belt was ok but it isn`t now! I have to say is is a bit the worse for wear!!
barrywi
Postby barrywi » Sun Sep 27, 2015 7:42 pm
Mike, can you write something for the X350 section of the magazine please when you have the job done ,I am sure the other person likely to want to go through the process would appreciate a description of the way you have done it! I met a guy at the Western day who has a Portfolio XJR who seemed to know what you were up to( unlike non engineer me!)
He said there are many ways to boost the power including changing top and bottom pulleys , I can dig out his email if you want to compare notes. Two things he did mention after talking about it for twenty minutes was "How much power do you need to break the law" and ( my favourite!!) " The diesel has nearly as much torque and at lower revs than the R so is nearly as fast"
I rest my case.
Postby J44EAG » Sun Sep 27, 2015 9:52 pm
Nigel has already asked me to do just that, Barry.
The diesel may have nearly as much torque but still not R level. I prove me case yer Honour!!! Sorry no diesel for me however good it is on paper. I can`t maintain such a power plant myself and DPF, exhaust and risk of a burn out make the car a non starter for me. Look at the ataggravation and cost our Rob has endured with his car recently. Bills of similar size to running his Masseratti.
Standard X350R has 408ft/lbs of torque. With the small pulley and K&N filter fitted, the figures will have increased somewhat. Rolling road figures will substantiate at a later date.
The later 4.2 engines have a larger crank pulley than the X308 which it replaced. Hence top and bottom pulleys being available for the V8 4 litre but not really necessary for the later 4.2 . A larger bottom pulley is however available for the 4.2 but the standard large pulley would have to be removed and sent to Powerhouse for modification. Lawson at Powerhouse informs me that there is little advantage in doing that mod for a road going car. Over boosting an engine would greatly affect long term reliability so just fitting the small pulley is where I shall stop as regards supercharger mods. This gives a moderate degree of road friendly tune. Believe me when I say the matter of tweaking the 4.2 has been a subject of a great deal of my own research before embarking on this uprate project.
One can modify for ever provided the cash is available. However there are often marked downsides in drivability the higher one goes in the quest for grunt. A moderate state of tune which does not destroy drivability is what I am looking for not drag racing potential. An ECU reflash in conjunction with small pulley installation is really as far as it will be necessary for me to go to achieve what I have in mind. It can be done in stages as funds allow. In doing so, I don`t want to create an irritable, unreliable, untractable pig of a car that is totally unsuited to everyday needs. That would be quite pointless. Mods will be spread across two or three areas of the car only and will be done in a way that spreads load across several component areas rather than hyping up just one part with the ever present risk of destroying it by overload. One has to have empathy with the machine and be sensible with what you modify. I`ve previously been employed as a research engineer and know that rash modifications done without thought or care, often fall far short of an acceptable outcome.
The old S-type is presently still much the quicker of the two cars car off the mark. Surprisingly so in fact. Very lively indeed. Touch the throttle and it is off. At the moment it is the better car around town. Less ponderous and seemingly exceptionally connected to the road in a very immediate and direct although rather crude fashion. Test pilots to date have found the car rather more of a rocket than they have expected. Many have found it quite a shock and somewhat intimidating. It is clear to me that most of those drivers have never driven a car that is rapid as this S-type.
The 350R has improved since fitting the new air filter. The old one was choked solid and was causing an air blockage on initial throttle pick up. A slight flat spot disappeared with the new filter fitted.
The 350R in standard trim is rather slower than the naturaly aspirated S-type until the supercharger builds up speed and pressure. For the short time the X350 managed to hang onto its aged drive belt this morning, with the new small pulley fitted, the situation definitely changed and the car was more responsive. I suspect that fuller benefits of the conversion to date would become more obvious if a reflash was also applied at a later date to this car. People often have a habit of poo-pooing the effects of a reflash. Some of the views expressed are opinioned by people who have never experienced the effects of a reflash. A reflash makes things happen rather quicker and throttle response is much more immediate. Less throttle is used to keep things moving which implies that torque gains become noticeable particularly on gradients. I`ve found a reflashed engine has a more fluid power delivery which makes the car easier and more pleasurable to drive...especially around town.
As previously said, Racing Green Cars offer a reflash service for this model year. I`ve discussed the method previously earlier in this thread. I shall also be talking to Tom Lenthal at TLJaguar in Berkshire who is a highly knowledgeable and respected tuner and is very experience at making great cars even better and at reasonable prices. Tom often posts on other Jaguar forums and has a wealth of knowledge that he doesn`t mind disseminating.
Tonight we await the new supercharger drive belt and will then have another go!
Postby J44EAG » Mon Sep 28, 2015 11:59 am
Broken! As described above. Will be making sure the new belt is properly fitted when the new one arrives.
Not a lot of space down the front of the engine. A bit of a cuss to get the belt out from under the crank pulley.
Here are the remains of my monument to folly and meanness. Part number on belt is 2W93-8620-EA.
Car now in pieces again awaiting a replacement belt.
Postby ptjs1 » Mon Sep 28, 2015 12:29 pm
Mike,
You will never again be able to criticise the depth of Rob's pockets and the shortness of his arms!
78k on original belt, supercharger in pieces, and you put back the old belt?!
I think I still have some old Champion N12YC spark plugs in the garage that were removed from my Triumph Vitesse 1600 38 years ago. Very worn but if you could grind down the body a lot and retap a thread , you might be able to hammer them into the engine of your 350R! I also have an old trackrod end from a Rover 3500 SD1 which you could perhaps braze on to your steering rack?
I know times are hard so let me know if you need any more bits!
PS Watch out for the 3 ghosts coming to wake you up tonight!!
Postby J44EAG » Mon Sep 28, 2015 3:39 pm
What a cruel little man that PTJS 1 is!
The priority plan was to get the car running well with the existing ancillary parts and spend the last of me wad on a gearbox oil change. Once the S-type was sold, then I would really hit the X350 hard on the remaining service items ie belts, plugs, oil, brake fluid, pads etc.
We were pretty shattered after doing the work on the charger mod. I suspect we just didn`t get the belt on correctly on the crank pulley. Too much dashing around in too small a time frame spoiled the job. These things happen. Nothing lost really as the belt would have been changed shortly together with other bits and pieces.
I seem to have got to know my way around the front end of the 350 pretty well now. I had the inlet air trunking, top hose, tank and old belt off in five minutes flat this morning. The wire spring clip securing the bottom tank hose to the tank connector can be difficult. Use long nose pliers going in and down from the right under the tank. Just pull the clip straight off and to the right. Don`t drop it. Its dark down there! Then the connector to the tank can be easily pulled off. Move the tank to the right to disengage two tangs from the body, disconnect the bottom sensor and the tank will come straight up and out.
A good tip to avoid waste, spills and salvage good used coolant is the use of a suction type oil extractor. I use a vacuum unit with a pot. Disconnect the two hoses on the tank and suck out coolant. This will empty the header tank and drop the engine coolant level to allow the top hose to be removed. Complete draining of the engine is therefore avoided. The short top right angle radiator hose can then be removed with only minimal coolant loss together with the tank which then gives access to the belt tensioner, crank pulley, fixed idler and so on.
I`ve just been given a fluid pump which I can plug into those two small top tank hoses and refill the coolant system effectively from the bottom upwards. This will expel air from the inter-cooler bricks and fill the header tank from the bottom also. This should avoid having to disturb a large 17mm hex fill/vent plug on the siamesed cylinder head coolant manifold pipe. Note also the air bleed by the smaller of the two top hoses. Opening this bleed point during the burping process is important to ensure full fluid flow and evacuate air. Note also that the cylinder head temperature sender is located in the manifold which also contains the thermostat.. This sender is easy to change which is fortunate as these units break down with age. Many will remember I had one give up at Weston Park a few years back. When failed, the sensor gives a full hot signal on the dash temperature gauge. That can be disconcerting.....
Whilst talking about that manifold and the thermostat, it is worth noting that the plastic thermostat housing and tower together with the plastic manifold found on the XK8, X308 and V8 4 litre S-type have been gloriously superseded by a substantial all in one aluminium unit. Thank goodness for that! The earlier plastic units could become a nightmare to dismantle due to plastic entitlement. Those units will not be missed.
barrywi
Postby barrywi » Mon Sep 28, 2015 6:02 pm
I have a sledge hammer to help with anything that does not fit but there may not be enough room under the bonnet to swing it.
Also the diesel can be upgraded power torque and economy wise with a reprogammed engine chip. I know someone who may be familiar to you that has reprogrammed his 350 diesel and fitted nitro to it , he outperforms XJR s regualarly at Santa Pod. Chipping is about £450 with a decent specialist using a rolling road to optimise the performance /economy/torque equation. I giggled when you mentioned heating up the pulley to fit to the shaft, it reminded me of a programme on the telly about fitting metal rims to wooden car wheels. I would have sorted your earth points out first as they can cause multiple fault indications.
I do admire your Flintstones approach to things though.....no criticism intended.
I promise not to mention the D word any more.....probably!
oldtimer
Postby oldtimer » Mon Sep 28, 2015 8:43 pm
He loves Diesels really, just a bit shy about telling us !
Postby J44EAG » Tue Sep 29, 2015 10:40 am
Horses for courses but not mine. This thread concentrates on the XJR and possible modifications.
For the technically minded in regard to the small pulley fitment and snout machining needed, the following dimensions apply.
The snout diameter was reduced by 5mm.
Some 2.5mm thickness of aluminium needed to be machined off the circumferential surface of the snout to reduce it to the recommended OD of 54mm.
The larger original pulley belt running surface O/D is 73.5mm.
The new smaller pulley belt running surface diameter is 66.5mm.
The new small 2.5lb pulley is therefore 7mm smaller than the original item.
The running clearance or air gap between the new pulley and the snout diameter is approximately 1mm tighter than the clearance of the original pulley.
By my reckoning, the supercharger is then driven approximately 10% faster than previously.
I`ve spoken to Tom Lenthall at TLJaguar in Wokingham, Surrey. Tom is well versed in how to get the best from supercharged Jaguars and will eventually be reflashing the ecu on my car. He was interested that Dave and I had done the 10%/2.5Lb pulley mod and will factor that into the map that he will build for me. The cost will be around £600.
Time to get the S-type moved on and release the necessary funds. I currently appear to have a hole in my pocket...
Postby J44EAG » Wed Sep 30, 2015 12:55 pm
And now another even bigger holes in me poche has occurred!
Just taking a breather after this mornings escapade. The new belt arrived. This was a double ribbed item rather than the smooth back OE type belt. I was advised this was indeed a later Jaguar mod item. So with great enthusiasm and confidence, I fitted it to the car and once again refitted all the other gubbins. I started up. All well. Then I took the car for a run. Sudden loss of super charger power again....WTF.. I immediately knew what had occurred. Belt chucked off AGAIN and as expected, a shredded mess.!!!!!
I phoned Harwoods in Chichester and the parts guy immediatly said he had a complete new updated mod kit of parts for the XJR. Apparently the original fit tensioner equipment has an issue. I`d not heard that previously but there we are. Rapidly loosing patience, I shot over to Chichester and bought the kit. I`m now £272 down on funds even with JEC/trade discount.
Now gathering up the tool kit and just about to go out to the car park and knock this car to bits yet again. Fred Flintstone Motor Repairs flys yet again!
More later with pics.
barrywi
Postby barrywi » Wed Sep 30, 2015 2:17 pm
Confucious he say " If it aint broke , dont fix it!"
And these petrol engines are so much more reliable than the diesels?
I hope you do not get too many skinned knuckles fixing it, I am genuinely sorry about your can of worms, it can only get better. :D
PTR200Jag
Postby PTR200Jag » Wed Sep 30, 2015 2:44 pm
Ouch!
Bit confused here though, if the car was running ok with the original pulley on and the , ahem, old belt along with the original (??) tensioner then the only thing that has changed is your new pulley?
If that is the case, is the pulley sitting correctly on the shaft?
Just take it easy with the hammer ! :roll:
XK8 MY2002
Postby J44EAG » Wed Sep 30, 2015 10:00 pm
It would appear I now have success. Read on.
Regret no pics tonight. I`m utterly exhausted tonight but will get back into this post tomorrow and edit some images to support this text. (Late edit. Images attached to two new posts below)
It matters not whether the model is petrol or diesel. One is not better than another when it comes to in service problems. Manufacturer recalls and TSB notices are a regular occurrences which hopefully become incorporated into vehicles in service as issues are discovered. A well known example of a TSB applicable to the X350 petrol or diesel models is the problem with the rear brake pipes and the foam incorporated into underside cover plates. Excess foam holds water and rots the brake pipes out. A TSB was issued advising inspection, clearance of foam and replacement of brake pipes if they where in a dangerous condition. A similar but more advanced methodology is Internationally used in the aviation industry.
Lets look what occurred on my car very closely and UNDERSTAND the engineering issues involved.
Firstly, my car threw its original slightly worn 78k mile old belt following the fitment of a 7mm smaller supercharger top pulley. This meant the supercharger would spin approximately 10% faster than a standard pulley with around the same figure of extra load being applied to its drive belt. Slippage could have been an issue but other factors were also involved, namely a degree of belt surface wear, minimal elongation of the belt, a known tensioner issue which possibly decreasing belt grip further together with a design issue which I only discovered this morning. The automatic belt tensioner although "on paper" had sufficient ability to cope with the smaller pulley and a mere 7mm/1/4 inch reduction around the pulleys and idlers running surfaces involved on this transmission train. Nevertheless, the problem of a second, this time NEW thrown belt again came to light after fitting and my engineering aptitude and gut feeling told me there was more to this issue than first conclusions suggested. Another problem therefore was in existence and needed investigation. That is one of the reasons my qualifications and time served experience allow me to be classed as a professional engineer, not just a mechanic. An engineer learns to expect the unexpected and has the nous to attempt to solve a problem.
My phone call to Harwoods solved the dilemma in a moment. The parts guy spoke to a technician who informed him that there was a mod kit designed to deal with a belt squeak issue but that more importantly there was a TSB issued which when applied in conjunction with a modified belt tensioner (the sprung loaded moving one) and a SERIOUSLY MODIFIED stationary idler pulley. I was told this would be effective and irradiate the belt throwing antics. The original stationary idler pulley was smooth surfaced and was devoid of raised lips to stop a belt slipping or being thrown off. I`ve always been wary of these lipless pulleys and have seen them previously on my V8 S-type. This WAS the jaguar designed retro mod I needed to stop the thrown belt problem on my car and it should have been fitted much earlier in the cars career.
The revised stationary idler pulley has lips front and back and more importantly V-grooves on its surface similar to those found on the crank pulley, the alternator pulley, the air-con pump and the power steering pump. Given time, thankfully Jaguar saw the need for the stationary idler pulley mod to also be made with those grooves and lips on it. Clearly my my car was long overdue for this modification but sadly those involved with servicing the car applied the principle of "If it ain`t bust, don`t fix it"! And that with a TSB already in circulation. In the aircraft industry, part of our job was checking for un-actioned outstanding service updates. That lead toward an aircraft receiving an annual Certificate of Airworthiness. The motor industry has much to learn and would appear to need its attitude adjusted for the better. Employing engineer grade staff instead of technicians might go some way towards a higher standard of technical service and excellence.
When I undertook my aircraft engineering exams, one could pass or fail the final exam held by the CAA by not answering one simple question correctly. I`ll never forget that question as it aptly defines the difference between a mechanic or technician and an engineer. You could asked "What you would you be looking for when examining a component or system"? The answer was "Anything unusual in the context of odd occurrences or visual oddities with that machinery". I used the same thought pattern today and suspected an issue with the smooth idler pulley and its inability to deal with a higher load situation and longer available length of used belt. To have thrown the belt once was unfortunate. To have it happen twice lead me to consult a manufacturers agent and come up with a solution. That occurred but not before two belts had been mashed to extinction.
In the kit is a new fixed idler pulley with circumferential ribs and lips. Its mounting bracket is identical in dimensions to the item it replaces with one small exception. The snout upon which the new pulley complete with bearing mounts, is 0.8mm shorter in height compared to the original bracket. I believe it would be possible to buy just the stationary idler pulley only and machine off 0.8mm from the old bracket with a 99 percent chance of success. In other words, with this light mod, the bracket could easily be reworked and be good for further service thus reducing purchase costs. I also question the need for a new moving tensioner when I suspect the original part fitted may well be sufficient.
The revised moving tensioner appears in all respects to be identical to the old unit I removed from the car. Part numbers were different but I am advised the tensioner internal parts are upgraded. Mnnnn.... A single 14mm hex head bolt secures the moving tensioner unit to a bracket upon which the alternator is also mounted. Two 8mm diameter location dowels pertrude from the rear mounting surface of the tensioner. Upon removing the central mounting bolt from the moving tensioner, it was found the whole unit was corroded on to that shared bracket. Copious amounts of WD40 were applied and a heat gun brought into play. Half an hour passed whilst I struggled to get this tensioner off the bracket. Eventually it came away but one of the cast "in situe" location dowels broke off the tensioner and was left within in the mounting bracket. Not good at all. An hour later using a right angle drill, I finally succeeded in removing the broken location peg from the bracket. A really nasty job which slowed things down all because Jaguar didn`t apply any anti corrosion product to the rear of the tensioner or the dowel location pegs. Typical of modern car building.
So with all issues sorted, I built the front end up again for the second time in less than eight hours, having turned the engine over on the starter so that I could visually check belt runs and to check that I definitely had the belt on correctly and its ribs engaged with any ribs on the pulleys and other like units.. Antifreeze mixture was replaced and the system burped.
Start up time went well. However I had to use my iCarsoft930i diagnostic unit to extinguish the MIL lamp on the dash. Turning the engine over without the MAF sensor connected to the airflow meter activated the engine check light. Clearing the fault code extinguished the lamp. Job done.
I`ve driven the car ten miles this evening and all remains well. No more thrown belts and hopefully the last I will see of this issue. So far, so good. (Late edit next day. Thirty miles now covered and all good.)
The car is now well quick with the new small pulley. The grunt comes in much earlier with a similar response I`m used to on my old Paramount tuned V8 S-type. Much better pulling out onto our nearly small and frantic roundabout and a most impressive grunt gain up the dual carriage way to the M27 and back. I`m now reasonably confident that this rework is more secure than previously experienced...Time will tell. as I often say, if you alter one thing, other effects and faults may show up....particularly if other updating has not been done in the past.
The final advice I offer tonight is that if you own a 350R, it might be a good idea to see if you have at least a ribbed pulley fitted to the stationary idler bracket. If not, it might be prudent to have this modification carried out.
Late edits subsequent to original post to correct late evening typos, grammar and content. M
barrywi
Postby barrywi » Wed Sep 30, 2015 11:32 pm
Well done Mike, you deserve a medal for the effort you have put in and a determination not to give up. My experience in general is that with any one job it always end up,being three jobs before getting sorted , I call it Barry's Law. Using that law it helps you to stay calm when it happens as new problems do not surprise you. An example would be when I decided to add more rust proofing to my SL Merc. Undo the tiny screws holding the sill cover to access holes to insert rust proofing dispenser. Do this job on a gravel driveway , drop screw and lose it in the gravel. New screw ordered from Merc dealer, not bad for a 30 year old car. Insert flexible squirter for anti corrosion gunk into holes . Lift hose out slightly too much and squirt anti rust gunk all over the sill and part of a carpet. Go for white spirit from garage to wipe off gunk , find empty container. Need to go to local diy shop for white spirit, cannot use Merc as sill covers removed, and wife is out in runabout car. OK so it was more than three events but the ten minute job ends up taking half a day, thank goodness for retirement!
On a lighter note...joke.
My dog is an engineer.
How do you know?
He made a bolt for the door.
I' ll get me coat....well done again Mike
