XF - one off or similar problems
Posted: Wed Oct 19, 2011 2:57 pm
by MattMatt
So my XF (2.7D) is now out of officail warranty although I have got an extension until next Feb.
I've had some problems which I wanted to check with others to see if they or unique or common
First - Gear control stuck. It was replaced but still can cause some problems by not engaging correctly
Second - Rear brake light went. They wanted nearly £100 (yes that's right) to replace the whole unit but I convinced them it should be under warranty
Third - The centre display sometimes doesn't start. Switching off then on seems to correct it
Fourth - the bluetooth phone module needed the firmware replacing to improve the mic sound (which was terrible)
Don't take this post the wrong way - I love my XF but I do like to be informed as to what other owners are experiencing
Matt
Re: XF - one off or similar problems
Posted: Thu Oct 27, 2011 10:15 pm
by andypryce
Matt,
I am new to XF ownership, so can't speak with any authority, but had similar repeated glitches with my S Type diesel, I gather that a software update will often cure these intermittent problems, might be worth asking the dealer whilst still under warranty.
andyp
Posted: Mon Oct 31, 2011 12:23 pm
by shugmcd
Thanks Matt and Andy for these inputs - I will be adding them to my database of issues.
Hugh
