Windscreen Washers
Posted: Sat Aug 03, 2019 12:20 pm
by r.walters2492
Can anyone help. I have a 2011 Jaguar XF 2.2 Diesel and I am experiencing an issue with my windscreen washers. As you know the washers are encompassed in the wipers themselves, the problem I have is that when I use the washers by utilising the button on the steering wheel arm the water squirts once from the wipers and also on the headlights, but then will not work again until such time as I switch the engine off for 15 minutes or so and then I can use the washers again but only squirting the once.
Any help would be appreciated.
With thanks Ray
