Satnav
Moderator:cawthrm
MalLew
Satnav
Postby MalLew » Mon Mar 20, 2017 6:29 pm
Can anybody recommend a more modern DVD for my 2009 XF-S?
Zennan101
Re: Satnav
Postby Zennan101 » Mon Mar 20, 2017 7:37 pm
If you mean an update disc then I updated my 2010 XF with a DVD I purchased from EBay. I don't have my transaction record but have the following contact address. 'Mysatnavdisc@ gmail.com'.
It cost me £24.99. Install was without any hitch and took just a few minutes. After update Satnav was updated correctly (missing roads appeared) looked and operated just the same as the official Jag install and has continued to do so ever since.
Send an email an see if they can help.
Rod
Ex 2010 XF 3.0 Luxury Diesel
Ex 2004 XK8 Coupe
holmesgordon31960
Re: Satnav
Postby holmesgordon31960 » Fri Nov 30, 2018 2:31 pm
Thanks for the info .
But where does the cd update go??
Zennan101
Re: Satnav
Postby Zennan101 » Fri Nov 30, 2018 10:10 pm
Eject the existing CD from the CD drive. ( If you haven’t found it it is in the boot left hand side as you look in) and pop in the replacement CD.
My update has been in over 18 months now without any issues. Probably time for another update...
Ex 2004 XK8 Coupe
