Att Ray Ingman
Moderator:blue.dye
Hi , i have a suspension problem , Harvey Bailey suggested i ask his advice , has anyone got contact details pls , ta Russ
Re: Att Ray Ingman
Russ,
If you go to "Model Forum", then "XJS", then select "Forum Contacts", you can find details for Ray there. If that doesn't work, come back here and we'll start again!
Re: Att Ray Ingman
Ta Paul , thx for ur reply , i couldn't c the forum contacts tho ? . Russ
Re: Att Ray Ingman
Russ,
The "Forum Pages" are not this part of the website - This is the "Bulletin Board".
If you look at the menu options at the top of this page, you'll see "Model Forum". From this option, select "XJS". You are then at the XJS Forum website pages. (Don't worry, many members don't seem to know about the Forum website pages for the various models!)
Once in the XJS Forum pages, select "Forum Contacts" from the top menu.
I hope that helps
I hope that helps
Re: Att Ray Ingman
Hi Paul , i found him thx for ur help , regards Russ
