Thought this might be the best section to get an informed response, does anyone know if the XJ40 shares the same steering column as the X300? Specifically the spline number and size.
I'm trying to find a boss/Hub kit to fit a steering wheel but nothing is coming up for the X300, I really would prefer not to have to have one made because I suspect that would be mega bucks.
I was hoping someone might have or know of one of those handy "shared components" charts where it will tell me the same steering column is also found on a similar era ford or something which has a boss readily available off the shelf.
I have a manual XJ6 that I am converting to run an LS3 crate motor with tremec 6 speed and will be taking the car on track days when possible.
Boss/Hub for 95 Jag XJ
Moderator:blue.dye
