Cold running, misfire, black smoke,
vernon
Postby vernon » Fri Oct 09, 2015 1:05 pm
Hi, I have been plagued by poor running when the engine is warming up.
It starts ok, but misfires when you try to excellerate until it reaches 75deg.
There is a mod! This fault is common with series 3 xk engines with Efi.
Technical service Bulletin, ref B-001 Vol V
This was issued by Jaguar Canada.
Model XJ6 Series 3 4.2
Subject: Air Flow Meter.
The cause is interference from the ignition circuit affecting the operation of the Fuel enrichment circuit.
The cure is to fit a 100uf 25volt electrolytic capacitor across pin 6 and 8 of the Air meter.
I have fitted this mod and it works.
Look for details on The Jag-Lovers Web site, under Xj lovers.
I hope this helps anyone else with this problem.
Happy motoring.
Vernon
Nostalgia Classic 120
Modern S type jag
