Electric Seat not working
rka
Postby rka » Sun Feb 28, 2010 4:56 pm
The electric seats on my series 3 1986 Soveriegn do not work. There is power going to the motors. I have bought 2 motors attached to their frames on ebay and I have fitted one to the passenger seat but no joy. Am I missing something? Where is the fuse? it does not appear in the places sugested by the manual. Is the fuse on the earth side of the wiring?
almcl
Postby almcl » Sun Feb 28, 2010 6:00 pm
There's an in-line fuse. Noramlly it's under the centre console, in a pink/white wire, but if you have power at the motor that can't be the problem.
The switch on mine operates in a non-intuitive way - press down to go up - which is a bit confusing at first.
Al McL
rka
Postby rka » Mon Mar 01, 2010 5:19 pm
Found the problem, a poor earth. Good enough to show current but not to take enough power. There is a screw holding a plastic clamp to hold down the wires under the seat. This provided a good earth. I was looking for something more complicated. My passenger will now be able to see over the dashboard! :lol:
Have you thought of turning the switch the other way up to be more intuitive. Mine will fit either way.
If anyone needs seat motors I now have 2 spare.
