Great YouTube channel
ChrisDixon
In researching the model I found a great channel called Living With A Classic including a 4.2 head stripdown carb tuning and other well shot and informative stuff including insight into the long stud version. Mostly based on an S2 that appears to have a later engine with the lateral cooling passages between the bores. They guy also has an XJ12 and XJ-S.
Re: Great YouTube channel
Chris,
You're right, the guy has some good videos and he also has a reasonable technical knowledge of the Jags. Worth watching.
Its partly because of this guy that I found the courage to have a go at mine...
