Indicator tell tale not working - xj6 series 3
Posted: Sun Aug 06, 2017 1:57 pm
by CliveRothwell
Dashboard indicator tell tale not working. So far I have checked:
Bulb, all wiring for continuity to both tell tale bulbs. All work / have continuity.
All exterior indicator bulbs work Ok but of course with the dash tell tale not working on the RH, it will fail an MOT.
Any ideas please?
Re: Indicator tell tale not working - xj6 series 3
Posted: Mon Aug 07, 2017 10:46 am
by mike020150
One suggestion is a failed blocking diode. There should be one each for left and right indicator lamps. Not having a series 3, I can't offer a suggestion where they are located but logic suggests the wiring close to the indicator lamps. Mike.
Posted: Mon Aug 07, 2017 8:45 pm
by CliveRothwell
all sorted - poor bulb connector contact. The real problem was that I was checking the wrong bulb!! Sorry folks.
