I own a 2006 xj sovereign occasionally car seems to jerk into gear shortly after yellow light comes on faults come up as abs gearbox fault and
Traction control. When light is on car jerks into reverse or into drive . at speed car drives perfectly warning lights go out one by one no loss of power and gearbox works perfectly
Gearbox fault
Moderator:Montana5
Re: Gearbox fault
Gearbox faults like these, can be caused by a low gearbox oil level. Checking the level is not straightforward so garages often get it wrong. As well as having the level checked either by a Jaguar specialist or a ZF gearbox specialist, it would also be a good idea to have any gearbox diagnostic codes downloaded. The latter might be able to pinpoint a fault or a need for a gearbox reflash, before the problem becomes serious or more expensive. Mike.
