Modern s type faults
vernon
Postby vernon » Wed Mar 12, 2014 4:29 pm
Hi a word to every one who has a modern S type.
If you have a fault with the car check the wiring loom first, most faults appear to be broken or corroded wires in the loom.
The main area found to be faulty is behind the front bumper or front wheel arches.
I've had two faults caused by faulty a faulty loom. 1 put the gearbox into fault mode the other caused problems with the heater.
It's easier to check the wiring first before expensive repairs.
Still would not part with the car. :D
Vernon
Nostalgia Classic 120
Modern S type jag
Re: Modern s type faults
Postby J44EAG » Wed Mar 12, 2014 7:34 pm
Agree many electrical faults can be put down to the loom behind the front bumper.
In addition other problems can be traced to the loom above the nearside front wheel arch liner and the section of loom under the air cleaner box.
vernon
Postby vernon » Thu Mar 13, 2014 6:00 pm
Think I now have another wiring loom fault, the button to open the boot has stopped working and it's not the switch.
So another hunt for the break is required. :cry:
Vernon
Modern S type jag
Postby J44EAG » Thu Mar 13, 2014 7:58 pm
Cable breaks where the loom is fitted on the boot lid irons are quite common on an S-type. Worth checking that loom section.
vernon
Postby vernon » Fri Mar 14, 2014 5:46 pm
Have tracked the fault to the loom behind the front bumper, it will have to wait until the next fault with the loom, not worth strip down for the boot button :D
Vernon
Modern S type jag
johnnewzealand
Postby johnnewzealand » Sun Oct 26, 2014 5:43 am
Hi all.
Just a wee comment on electrical problems with S-types, for what it's worth!
Mine a 2001 SE 3L petrol, and I've NEVER had any problems whatsoever, except for a new battery that I replaced after 6 yrs. - no indication of a tired battery, one day when I switched on, everything went "haywire" - instruments and readout went all over the place. Bought a new battery, and everything went back to normal.
I have cleaned my car very carefully regularly, underneath as well as on top, heaps of water, etc., especially frontal area undersides. Also, about once a year, have removed the wheel arch plastic trims (splash guards?), and plastic under trim under engine.
I have had my car serviced on time, every time, by Jaguar agency, not cheap!
However, I have a car that I still enjoy driving, and one that is trouble free.
So, if anyone is thinking about a modern S-type, I'd say go for it, but !!!! look for a maintenance history, and spend time looking after it!
John.
johnnewzealand
Postby J44EAG » Sun Oct 26, 2014 10:09 am
Preventative maintenance is what it is all about, John.
As with all machinery, failure to inspect and rectify aging components ensures that failures are more likely to occur. It also means that neglected items all start to add up and eventually very large rectification costs materialise.
Regular engine oil changes, particularly on the V6 petrol models cannot be ignored. A poor oil change regime usually leads to top and bottom end oil starvation due to internal oil way blockage. One day the car is fine, the next day the valve gear becomes noisy or big end failure occurs.
5R55N auto transmissions also need regular oil changes. The life of the Mercon V transmission oil is not indefinite. Whilst these transmissions are said to be filled for life, the life of the transmission is very much influenced by the condition of the oil. Transmission oil changing should be carried out by a garage equipped with full flush oil change equipment which flushes out the transmission, the oil cooler and the torque converter. Anything less than that is to be regarded as only a partial oil change.
Any engine misfires should be attended to quickly. Misfires are usually down to worn spark plugs and failure to keep them replaced at the required intervals also leads to individual plug on coil pack failure.
Premature suspension wear can be a problem on cars used hard on poor roads. Wishbone bushes, ball joints, ARB links and ARB insulators need regular inspection to avoid a noisy suspension and tea trolley like handling developing.
Many UK based cars can be troublesome which is often down to plug and socket corrosion. Cars operated in dryer climates are likely to be more reliable. However, all models and years of S-type can be susceptible to broken or rotted wiring, particularly within the left wheel arch and behind the front bumper cover. Cable quality is not the finest and it is installed very tightly in places which can lead to failure.
As with all machinery, some examples work and survive for longer than others. This can be down to original build quality, subsequent maintenance and the way in which the machinery is treated when in service. There exist examples of the good, the bad and the ugly with any make or model of car. The S-type is no exception.
The more we all do to keep on top of our cars, the more reliable they are likely to be. Particular attention should be paid to areas of the car or machinery which are not covered by the typical service schedules. Gearbox oil changing is not listed on those schedules and must therefore be singled out as an item needing special attention. Many Main Dealers have started to take note of this special need but I suspect not all will be so actioning this item preferring to let a customers transmission disintegrate and to then sell him an expensively fitted new unit. Cynical but often true.
Keep up the maintenance and enjoy your car.
johnnewzealand
Postby johnnewzealand » Tue Nov 04, 2014 7:18 am
Hi all.
Posted a comment on my 2001 SE model not long ago re electrical problems, and stick by my comment, - i.e. well maintained and it has NEVER missed a beat since new, done 242,000kms. Always serviced by Jaguar agency, but more importantly perhaps, thoroughly cleaned regularly.
In the last week have been thinking of updating (another S-type of course), and have been looking at 2004 onwards.
Have noticed that all these (facelift?) models, don't seem to have a lower plastic covering under the grill, i.e. that covers the wiring loom that runs across the inside front bumper? My 2001 has a secondary plastic cover that covers the wiring loom? All the "newer" models, 2004+, have the wiring loom sort of exposed? O.K., it is wrapped in insulating tape, but doesn't seem as well protected as on my 2001 model? Any comments?
I can only assume Jaguar (Ford) were trying to cut costs?
Perhaps a reason for that wiring loom being problematic in "some" cases?
Interested in any comments, johnnewzealand.
Postby J44EAG » Tue Nov 04, 2014 10:57 am
There doesn`t seem to be any common theme running as to whether early or later cars are more or less susceptible to cable faults around the front or near side wheel arch areas.
Faults tend to be due to either rotted cable or breaks. As discussed in another thread on this Forum, cable quality is not the best and certainly not up to aircraft grade standard. Being automotive un-tinned copper sheathed in basic auto grade sheathing, the cables can degrade at an alarming rate. Wet operating conditions appear to exacerbate failure.
As far as cable breakage is concerned, this seems to be a particular problem where cables are tightly installed and bent through sharp angles. The section of cable under the air cleaner box is particularly susceptible to failure.
oldtimer
Postby oldtimer » Sat Nov 08, 2014 11:00 pm
Hi All,
What is your view in regard to my dilemma. I have no electrical problems (will probably regret writing these words) do I leave well alone or is it worth examining the looms with particular attention that Mike and Vernon refer to ???
Oldtimer
Postby J44EAG » Sun Nov 09, 2014 2:08 am
If it `ain`t bust, don`t try to fix it! Difficult to target a target that desm`t present itself.
Concentrate on behind sill corrosion. That should give you a few grunts of satisfaction, Phil.
oldtimer
Postby oldtimer » Sun Nov 09, 2014 10:56 pm
Hi Mike,
I guess that's about right
P
vernon
Postby vernon » Wed Nov 12, 2014 12:48 pm
All my loom faults have been due to corroded wire on the inside conductors and all have been the same colour cables.
If yours is ok best left alone, when or if you have a fault, then replace all the same colour.
My view is the wire used was faulty to start with and just a matter of time before they failed.
Fingers crossed and happy motoring.
Vernon
Modern S type jag
Postby J44EAG » Wed Nov 12, 2014 4:47 pm
The cable used is just common or garden automotive flex. In the marine industry I expect any boat wired with such cable to need at least a partial rewire around ten years after installation of that grade of cable. Cars might just see a slightly longer service by three or four years if you are lucky.
Had the manufacturers use aero or marine tinned grade cable then we would not be seeing anything like as many electrical connectivity issues as we see with our vehicles.
vernon
Postby vernon » Fri Nov 14, 2014 3:44 pm
I also have a boat and know what you mean.
Have you seen an Stype loom?
Most of the wires would not conduct more than an amp without melting, most are signal only, but the quality used is very poor.
I think the sheathing on these cables is not water proof, hence the corrosion.
Vernon
Modern S type jag
