I need to replace my windscreen wipers….
They have the washers attached to them..
Which replacements should I go for?
Cheers Rob
2007 STR
New windscreen wipers recommendations
Re: New windscreen wipers recommendations
Go to SNG Barratt they list the correct wipers for the S Type with the washer bit attached, only trouble is they are on "Back Order" which is pretty useless for something needed now. Halfords list the wipers for the S-type with multiple connectors which means nothing because none of them are the right ones. You need to remove the connector from your original blades and fit it to the Halfords blades, a bit of a problem is however they are a tight fit and don't allow the blade to flex in operation. All a bit frustrating. Its a suck and see regime, or don't use the car in the rain, buy a Mini.
Dave Hart
