Windscreen wipers
mak485
Windscreen wipers
Postby mak485 » Sat Aug 10, 2019 5:42 pm
Is there any adjustment to prevent wiper hitting the A post on my 07 s type
jeff1954
Re: Windscreen wipers
Postby jeff1954 » Sun Aug 11, 2019 5:28 pm
First of all make sure that you have got the right blades fitted ie not to long. If they are the correct length then you could try releasing the arm from the spigot and moving it down a couple of splines and see if that cures the problem. If it doesn't there may be excessive play in the mechanism.
Jeff
Previous Jaguars.
1967 3.8 S Type.
Series 1 XJ 4.2
Series 2 XJ 4.2
