Tow bar
stypesteve
I had a tow bar fitted about two years ago and it was the worst thing I could have done, when the car is started from cold the back boxes vibrate on the heat shield for a few minutes until warm. Looking forward to having it removed. Has anyone else had these problems ?
Re: Tow bar
It's the car telling you it is not designed to tow a caravan - like putting a milkfloat behind a Derby Winner- and to get it off again ASAP.
1994 Coupe AJ6 engine
Re: Tow bar
Hi Paul,
Sounds like a lousy fitting job to me or an inappropriate tow bar, certainly not my experience.
Re: Tow bar
Or just the heat shields not being fixed up correctly?
Worth also checking the condition of the exhaust hangers on the back exhaust boxes. They fix up to the rear ali bumper bar which can corrode out letting the exhaust drop and rattling and knocking noise.
Re: Tow bar
Isn't Steves car a later one and so has the later steel crossmember??
When I took my exhausts off and dropped the rear subframe I removed the exhaust heat shields and found the aluminium around the locating nuts had rotted off, so used large steel washers to resecure it all again.
PS Its nice to see you back on this forum again Oldtimer, I missed your caustic wit (did I spell that right!)
stypesteve
Re: Tow bar
Re: Tow bar
I have a Witter detachable tow bar fitted sensitively by a local specialist on the box was a Jaguar Part number. No vibration and tows my small 2 birth with ease.
