Additives
trevor.pocklington781
Additives
Postby trevor.pocklington781 » Mon May 02, 2022 9:37 am
Good morning all.
Does anyone have any experience of using Wynn's diesel injector cleaner and DPF cleaner with the S type 2.7 twin turbo diesel engine.
I would like to know if it is safe to use and if my Jag will then go twice as fast !!!!! :D
Take care.
T
andypryce
Re: Additives
Postby andypryce » Mon May 02, 2022 7:04 pm
Certainly safe to use, but sadly it will not go twice as fast!
XF Sportbrake 2020 / XK8 1998
rosemary
Re: Additives
Postby rosemary » Mon May 02, 2022 7:49 pm
Definitely works clearing a coked up injector, no misfire after use, certainly noticeable at idle. Don't know about DPF cleaning my car has downward facing tail pipes which suggests it doesn't have a filter, escaped from Jaguar when constructed.
Dave
Dave Hart
Re: Additives
Postby trevor.pocklington781 » Fri May 06, 2022 11:35 am
Dave
Thank you.
T
Re: Additives
Postby trevor.pocklington781 » Fri May 06, 2022 11:36 am
Thank you.
T
