Tyre inflation procedure
TheColonel
Postby TheColonel » Sun Aug 01, 2021 8:32 pm
I have recently bought an S type and find the tyre inflation procedure unusual. It needs the valve cap removed with a flat key then an inflator spindle screwed in before a normal footpump can be used. Is this a peculiar Jaguar / S type or alloy wheel fitment? Haven’t come across it before on any other make.
Michael
andypryce
Re: Tyre inflation procedure
Postby andypryce » Sun Aug 01, 2021 10:56 pm
Hi Michael,
Certainly wasn't like that on my S Type, just regular valves. I wonder if at some stage someone has fitted non Jaguar wheels?
XF Sportbrake 2020 / XK8 1998
TheColonel
Postby TheColonel » Wed Aug 04, 2021 8:47 pm
Hi Michael,
Andy,
Not sure if they are originals or not - I've attached a photo.
Michael
JimboV8
Postby JimboV8 » Wed Aug 04, 2021 9:16 pm
The procedure you describe for those wheels is correct. BBS 3 piece alloys I think they are.
2012 XKR, Black pack, Aero pack, Speed pack 8) :mrgreen:
​Past:-87'XJS 3.6L, 93'XJ40 3.2L gold, 95'XJ6 4.0L sport, 00'XJ8 3.2L sport, 2005 XK8 4.2L, 2009 X150 5L Portfolio coupe, in that order and enjoyed all of 'em. :D
andypryce
Postby andypryce » Wed Aug 04, 2021 11:45 pm
Interesting! Obviously much posher wheels than I have ever had :D
TheColonel
Postby TheColonel » Thu Aug 05, 2021 9:01 pm
Jimbo,
Thanks for the reply. This raises another question - if they are 3 piece rims does this cause problems in fitting new tyres? I'm aware of older Land-Rover wheels known as split - rims where undoing the middle set of bolts can potentially be fatal. Is a Thick Fit fitter going to be able to fit a new tyre or does the rim not need dismantling to fit a tyre?
Michael
JimboV8
Postby JimboV8 » Thu Aug 05, 2021 9:14 pm
Jimbo,
Michael
No problems whatsoever Michael. Tyres are fitted in the same way as a conventional solid wheel. I had the Detroit BBS wheels on my XK8 and never encountered problems changing tyres.
TheColonel
Postby TheColonel » Fri Aug 06, 2021 3:13 pm
Thank you for the reassurance on this.
Michael
JimboV8
Postby JimboV8 » Fri Aug 06, 2021 3:22 pm
You’re very welcome Michael, enjoy. :mrgreen:
