2.7 Diesel Turbo Fuel burner
GeorgeD2
Postby GeorgeD2 » Fri Mar 30, 2012 11:34 am
The fuel burner in my S type 2.7 diesel which is designed to heat up the engine and internal cabin is supposed to activate whenever outside temperatures fall below 5 deg C but fails to do so. I have had the fuel burner itself replaced by and authorised Jaguar dealership but this hasn't resolved the problem. It seems that whatever process should activate the fuel burner isn't working and my Jag dealership say they don't know why and can't do any more. Any advice will be much appreciated
daven
Re: 2.7 Diesel Turbo Fuel burner
Postby daven » Sat Mar 31, 2012 12:50 pm
There are several things that will prevent it from firing up, these are those that I can remember:
1, Ensure you have the Climate Control in Auto.
2, Ensure the Low Fuel warning is not lit.
3, Low Battery Volts will also prevent it from firing up.
I would also check that there are no blown fuses etc.
If the above is OK, I would advise contacting an authorised Webasto service agent.
Cheers Dave
Montana5
Postby Montana5 » Sun Apr 01, 2012 1:59 am
Some useful info about Webasto Heater on this thread...
http://www.jec.org.uk/forums/viewtopic.php?f=195&t=5632
Doug.
S Type Forum Moderator
jeff1954
Postby jeff1954 » Sat Feb 27, 2016 6:33 pm
Anyone that's having problems with there Fuel Fired Heater starting up should try this. Once the heater has been re set turn the climate control off before starting the engine After starting turn on the climate control to get the FFH to fire up. When you get to where your going turn off the FFH before stopping the engine then it should fire up next time.
I have found that if the FFH goes through its full burning cycle it will fire up again when you turn off the engine even if you leave the climate control on, but not on short journeys when its not completed its cycle. Give it a go and see what happens you may be well chuffed as I was :D
Previous Jaguars.
1967 3.8 S Type.
Series 1 XJ 4.2
Series 2 XJ 4.2
thomas45
Postby thomas45 » Wed Mar 02, 2016 6:12 pm
Mine fires up regularly when outside temp is low but I often wonder if there is any benefit. There is noise and some smoke from it which before I learned what it was it became quite alarming. :)
Thomas
robv12
Postby robv12 » Wed Mar 02, 2016 9:17 pm
AGREED!!!!
Thomas
jeff1954
Postby jeff1954 » Mon Apr 04, 2016 5:03 pm
Don't go off the temp gauge, put your hand under the foot vent you will feel warm air coming through after a couple off minuets. It seems to me that the warm water goes strait from the burner to the duel heater valve then into the cabin. Even when the cabin is warm it still takes a while for the temp gauge to rise significantly.
Jeff
Previous Jaguars.
1967 3.8 S Type.
Series 1 XJ 4.2
Series 2 XJ 4.2
