Hello Tony,
My initial thoughts are that now you have replaced the tie rods with integral outer ball joints from the subframe to the rear hub is that the rear tracking may be out of limits. However from what you describe as movement which I assume is between the lower hub carrier link and the outer patent bush in the lower rear wishbone unit implies that you may have a problem with worn lower wishbone bushes.
These bushes are unique in design. I wrote a big article on the subject in our magazine last year about them. There are three bushes in the lower rear wishbone. One is a hard wearing long life rubber Metalastic type unit which seldom gives issues. That is the bush in the wishbone found effectively just to the rear of the sill. The two other bushes are the patented type and are a notorious wear issue on the car.
Now then. This is where the fun starts. Originally, these lower rear wishbone units and their bushings could only be replaced via Jaguar as a complete unit at around £470 per wishbone! Later, Neville Anderson at North East Jaguar Spares found an alternative source of supply for these wishbones and began to make them available at a much more affordable price.
Later still, Racing Green Cars Ltd managed to source replacement bushes for around £50 each. Neville now stocks these bushes as well as complete new wishbone units. We all breathed a sigh of relief when these replacement bushes hit the market but it should be noted that fitment of those bushes is not a Jaguar approved repair method due to the risk of wishbone register cracking occurring.
These bushes are not a normal item generally found in wishbone units and great care is needed in fitting them if you go this route. A bench press is needed for removal and fitment of new bushes and a specially dimensioned mandrel must be constructed to facilitate those operations. Use of ratchet sockets as push mandrels are rather unsuitable due to incorrect wall thickness and other dimensional issues. However given the right man and equipment for the job, it can be done but you must expect that a wishbone may crack during the rebush process. Fitment is at your own risk. Note that a 20ton+ hydraulic bench press is also required to change bushings. Attempting to do such work with even the largest of bench vices, tubes, spacers and other cobbled up paraphernalia is a non starter. So that is the basic start point for rear wishbone replacement or repair given that wear is evident in one or both wishbone bushes.
Replacing the link rods could well now cause excessive wear in rear wishbone bushes to become evident and your car to handle like a tea trolley as a result. I`d suggest you go over the rear wishbone bushes with a fine toothcomb and replace any worn items.
Having done that, I would also be looking at the front suspension for wear issues. Begin by ascertaining that wear is not evident in the outer steering rack arm ball joints. Then jack the car at the front to lift the tyres to a height of around two inches and insert a lever bar between the ground and the bottom of the tyre. Have someone lift on that bar whilst you look for up and down movement between the lower from wishbone and vertical hub carrier vertical leg. The ball joint fitted to the bottom of the vertical leg is a frequent failure point on early pre MY2002 S-types. That done, also lever all wishbone inner bushes and check for wear also in the upper wishbone ball joint. Wear found in that location means fitment of a new upper wishbone arm. Again Neville can supply these at good prices.
Having found and replaced all worn suspension items on all wishbones and vertical leg ball joints, THEN have the car retracked using a four wheel alignment system. Don`t bother to have the car tracked until you are totally satisfied that all bushings and ball joints are in a condition fit for further long term service. Only by use of such equipment car the car be made to drive in a straight line and handle correctly. Correctly set up, the car will be a joy to drive. If that is not the case then intensive investigation is needed.
Polybush do indeed market bushing kits. Expect to spend at least £500 for a kit! I must however add a word or two of caution. I have examined one of these kits and am personally greatly concerned about the suitability of installing solid polyprop bushings within the lower rear wishbone. Doing so would in my opinion destroy the special design aspects of the original patent bush which allows tangential and circulatory axial movement which is needed within the jointing of the lower wishbone unit. The use of a poly bush at the wishbone/lower hub carrier location would make rear tracking adjustment almost impossible as a poly bush would solidly fix alignment and not allow rear tracking adjustments to take place. In all other wishbone locations on the car, I can see no reason why Polybush bushes should not be used.
http://www.polybush.co.uk/shop/697_Jagu ... _1999-2002
Seen how you get on with these ideas and come back to us if you still have problems.
