strange suspension probs -please Help ?
oldtimer
Re: strange suspension probs -please Help ?
Postby oldtimer » Tue Feb 02, 2016 9:59 pm
Mike,
Lets concentrate on DGLICK 's problem not a history lessen in regards to your vehicle. :) :wink:
DG Despite what the garage has told you and I don't dispute what they have to say, but a significant defect is eluding them and you.
Sadly, you chose not to fully answer the question that I asked in my attempt to help you !
ARE THE WHEELS AND TYRES NOW FITTED BRAND NEW - IF NOT DID THEY COME OFF A VEHICLE INVOLVED IN AN ACCIDENT - Has any body inspected each rim and carried out a run out check with the tyre removed - has anybody carried out a run out check of the discs and hub face - do the people doing your work know how to do that.
Earlier you said that you had some Brake work carried out - what exactly ? Were the Discs replaced - was a disc "run out" check carried out and the results recorded.
I am still convinced from your description that the problem is confined to a rotating assembly.
I await your response
Oldtimer
oldtimer
Postby oldtimer » Wed Feb 03, 2016 5:22 pm
Mike,
Apologies for my "smart Alec" remark in resect to your thread above.
I am trying to drill down and find a fundamental cause of this alleged Wheel Wobble that DG is having so much trouble with.
At this stage I am still convinced that it is a rotating assembly causing the problem
Oldtimer
