vibration through the car at low speeds
derekgeee
Postby derekgeee » Mon Dec 07, 2015 2:36 pm
Hi my 2007 S type diesel has a strange intermittent vibration through the vehicle at speeds between 30 to 40 mph. if i accelerate harshly it does not appear. Any thoughts anyone? :(
the car has done 140,000 wonderful almost trouble free miles. :D
Montana5
Re: vibration through the car at low speeds
Postby Montana5 » Wed Dec 09, 2015 12:54 am
Firstly the simple stuff:
Are all the wheel nuts tight, have had this happen twice with other Cars, only noticed on the over run, once when Garage hadn't tightened Nuts and secondly a few weeks after Wheels had been Powdercoated, Nuts bite into the new coating, then gradually became loose and needed re-tightened.
Bulges or defects on Tyres.
Warped Discs.
Engine Mount rubbers split/worn.
Propshaft Joint rubber coupling (doughnut)
Doug.
S Type Forum Moderator
derekgeee
Postby derekgeee » Fri Dec 11, 2015 12:38 pm
Thanks Doug I will check your suggestions and get back to you :D
derekgeee
Postby derekgeee » Mon Jan 18, 2016 8:26 pm
Warped Discs.
Hi Doug
All the above checked and all ok. My expert has cleared all fault codes to see if anything turns up on my next visit to get the flexi joint on both cats repaired :(
Postby J44EAG » Mon Jan 18, 2016 8:55 pm
I recall there is an intermediate "plummer block" type bearing half way along the prop shaft. If that were gone you would certainly get vibration.
Don`t forget the obvious wheel out of balance issues that can occur at various speeds or tyres that might have flat spots. Cheap tyres of uncertain parentage and perhaps poor construction can be problematical.
derekgeee
Postby derekgeee » Thu Mar 03, 2016 8:36 pm
HI Guys The latest is, my expert thinks it might be the torque converter. no fault codes present, the fault is intermittent with all gear changes smooth as silk. i will be consulting my local gearbox man soon. The plot thickens. :cry:
