My car is currently being serviced and Ive been informed they cant release the fuel filler cap via the interior switch.
Is there an override procedure for release?
Krish
Fuel Filler Cap_Override Release?
latebreaker
S-Type-R, 2006, Midnight, Charcoal Sport, CD Autochanger, Bluetooth, JaguarVoice and now 19" Barcelona's
Finally a Jaaag Owner, and it feels good
Petrol, The Breakfast of Champions!
It Doesn't Click or Buzz.....It ROARS
Re: Fuel Filler Cap_Override Release?
Hi Krish,
Open the boot and pull the release cable. On the right just below the hinge . Should be a tag on the cable end that says fuel cap release. This is held in place by a bit of Valcro
Hope that helps
Oldtimer
Hope that helps
Oldtimer
Doh!
Who is servicing it.........
TonyS
TonyS
XJS Bulletin Board Moderator
latebreaker
Thanks Oldtimer,
It appears a fuse was blown when they performing the filler flap mod at my request. Fuse replaced and all good.
Krish
Krish
Hi Krish
Let us into the secret what mod is this. your Mod or an approved Mod?
Oldtimer
PS Did you find the release cable in the boot
Oldtimer
latebreaker
Hi Oldtimer,
Nothing exotic
, I gave them a TSB which gave instruction to modify the fuel flap to make it easier to open and close as the effort required to close it was becoming greater each month. All sorted now.
I think they changed the fuse so the manual override you suggested wasn't needed. I'll have a look for it later as it would be quote handy if it ever refused to open.
Krish
Nothing exotic
Krish
