Removal of sill cover and corrosion advice please.
Postby J44EAG » Wed Jun 12, 2013 7:29 pm
Guys,
I`ve had a member mail me this afternoon.
He asks how the plastic sill cover is removed as he wishes to treat the corrosion evident in these two images.
Comments and advice if you could please.
https://mail.google.com/mail/?ui=2&ik=5 ... &safe=1&zw
Martec
Re: Removal of sill cover and corrosion advice please.
Postby Martec » Thu Jun 13, 2013 12:19 pm
The sill cover is a plastic cover, from underneath there are 7 or so plastic screw things that need to be removed (unscrew and pull them out). Then carefully pull the plastic sill cover horizontally, best with 2 of you doing it, it is held on with several push in/pull out guide pins.
I also have two small holes in the sill about a foot back from the front, will be welding them up this summer.
Postby J44EAG » Thu Jun 13, 2013 12:26 pm
Thanks Brian.
Useful info.
Martec
Postby Martec » Fri Sep 20, 2013 9:08 pm
Well I bit the bullet and have now removed the sill covers and found a hole in each sill, cut out the rot and welded a plate in to replace it.
I started by removing the 8 plastic clips/bolt things that hold the bottom of the sill cover, then eased the rear of the sill cover horizontally away from the car, you can hear the plastic clips inside popping out. My wife held that end whilst I pulled the front off and it all came away easily except one of the white plastic bits (socket) broke. The other side I took off on my own by easing the rear end first and then the front but allowing it to fall onto a padded surface (one of the wheels I had taken off).
Both sills are holed in the same place, on the bottom surface (horizontal) and at the second plastic clip hole from the front (below the forward end of the drivers door).
I was concerned about welding with all the ECU's still in the car but followed a friends advice and disconnected both battery terminals. I disconnected it yesterday and cut out the rot and today welded steel into the hole. After all the welding and grinding was done I reconnected the battery and all seems to work OK, engine fired first time and the door locks and lights worked as they should. After removing a bit of surface corrosion on the sills I've now used etch primer and Crown black gloss.
The 3 tins of Dinitrol Cavity wax arrived today and the replacement plastic clips should (I hate that word) arrive tomorrow. Apparently the original 2 part clip is now replaced with a one part clip!!
So tomorrow I start taking out the corroded brake pipes and refitting in Cunifer (I bought another roll today). That will make two cars brake pipes done this year and 3 more to MOT yet!
oldtimer
Postby oldtimer » Mon Sep 23, 2013 9:58 pm
Hi Mike, Brian and all,
I've been reading articles and entries on here about corroded sills for what seems for ever.
Nag Nag Nag that's all we get, so I decided that I had better have a look. I take all the under panels off most years and find a liberal layer of stone chippings and mud but never the sill covers.
So, today being dry, lets do it. Half the eight fasteners along the bottom edge of the sill came out OK, the remainder were pulled out using a pair of wire cutters like extracting teeth, so they are fit for the bin. With both doors shut and a pile of old rags beneath, a sharp horizontal pull at the front and things started to move (Well two or three sharp pulls)and the same to the rear end. I then sort of pulled and rolled the sill downwards a bit and it seemed to un clip OK. The ten bullet type clips at the top edge survived OK. All just as Brian described.
I'm highly pleased to say that there is absolutely no corrosion what so ever. The paint finish to both the internal and external surfaces of the metal sill are as new.
I finished taking off the first sill cover late this afternoon so need to have another look tomorrow to confirm. On first inspection there appears to NO drain holes in the length of metal sill although the front end of the sill is open, only closed off by the plastic wheel arch liner and then overlapped by the return of the sill cover. What I am interested in, it looks like an inch diameter metal pipe comes from above and may be the water drain pipe from around the near side wiper spindle. If indeed this is so, then water is pouring down that pipe straight into the inside of the sill. When I first dropped the plastic sill cover a generous amount of mud and silt fell from around the location of the pipe I just referred to. Now my car is cossetted in the extreme, so is it possible that daily work horses accumulate mud and the like to an extent that water is unable to drain away. This could result in water accumulating within the sill causing the corrosion to which Brian referred
Brian , in an earlier note you indicated that perhaps the plastic sill was chafing with the metal sill and was the cause of the corrosion - would you care to expand on that.
It would be sad if all this aggravation was the simply the lack of a couple b*****y drain holes.
I'll have another look tomorrow, I might even pour a drop of water around the wiper drain and see where it comes out!
Oldtimer
Postby J44EAG » Tue Sep 24, 2013 5:52 am
My hat off to you in admiration to you both for your work on anything below door handle level.
Regret to say I have developed a vicious case of sciatica which is precluding me doing almost anything on my car at all presently.
I have to say I`m dreading a 70 mile trip to Surbiton this afternoon to see a back repair wizard. Perhaps having spent a thousand pounds on a patch up job, I may be able to join in the maintenance fun again. In the meantime, please hold the fort for me!
oldtimer
Postby oldtimer » Tue Sep 24, 2013 10:38 pm
Hi Mike, Brian and All,
We will hold the fort whilst you get your back fixed Mike.
I would suggest that all S Type owners give a thought to removing the sill covers for cleaning and inspection. It might save a future nightmare. The sill covers do come off remarkably easy but be prepared to buy a handful of replacement clips for refitting.
So this afternoon I had another inspection of the sill area. Firstly I poured water down the N/S wiper spindle scupper and discovered that the water goes down the rubber tube to where it joins the inner wing and then free falls between the inner and outer wing and cascades onto the inside of the plastic sill cover. As regards the steel tube that I thought was the drain pipe, that is rubbish, it is a half round piece of the body structure. By examining the sill cover not removed at the other side it can be seen that adequate drainage especially around the jacking points exists. Despite this, mud and road silt accumulates particularly at the front end. Should this exit passage be blocked or restricted then water will enter the metal sill which is completely open ended. To repeat myself, my car is cossetted to beyond belief and yet the evidence was building with copious amounts of road muck, silt and tiny stone chippings, oh and a couple of leaves.
This time armed with a lead lamp and mirror I examined the lower edge of the metal sill and discovered three drain holes on the inner bottom edge, these are spaced from the B post to the front with none to the rear of the B post. Should the car be parked on a slight nose up incline, I guess water could regularly run to the rear of the sill with no escape route.
That's all for today
Oldtimer
oldtimer
Postby oldtimer » Fri Sep 27, 2013 9:18 pm
Hi All,
Just a bit more, I didn't mention it earlier, that an internal stiffener rib runs the length of the sill. This rib can be seen through three access holes on the outer face of the sill and is about half way between the front and back faces. There are also access holes in the stiffener matching those on the outside face.
The reason I mention this is in connection with Wax Oiling. Using the access holes described the flexible extension for the Wax Oil gun will reach both sides of the centre rib and ensure all areas are suitably waxed.
That's All for tonight
Oldtimer
Martec
Postby Martec » Fri Sep 27, 2013 9:26 pm
Just back from Brum and read the posts above, I hope the 'Expert' improves your back. I hurt mine 35 years ago and so lived on pills plus some one who pulled and stretched it and now a lady who works the muscles. After a really bad winter (pain) my back appears to have cured itself!!!! so I hope you get relief a lot sooner.
Hi Oldtimer, The car is still jacked up and only 9 out of 10 brake pipes replaced but more supports are needed. I can't get the two above the fuel tank out so cut them off for now and rerouting the pipes beside the fuel tank.
The sills on my 2000 car are closed off at the front end, but with a nasty edge showing. I've looked at Rogers spares car and ours and it seems that like many others Jaguar has not learned the old lessons. The sill is made up of 3 sections, outer, centre and inner, with reinforcing pieces added to allow jacking up on the sills, BUT drain holes would be nice.
The outer sill has holes near the top and no drain holes that I can see, the inner sill area has no holes at all, but very narrow slots which clog up easily. My intention it to drill about 4 3/8" holes in the inner and outer sill and then twist them aft so as to drain properly - it works a treat on the MkII. Again as with the MkII there are a lot of open box sections front and rear with signs of surface corrosion, these will all be waxed, but I do remember a question in JE magazine where another member had waxed the box sections and ended up muffling an alarm horn - I'll need to find that.
The corrosion on my sills are where the plastic sill cover is held up to the sill, this is at each plastic clip as there is a landing about 1" square. The crown paint is nice and dry so a coat of underbody wax can be painted on when I've finished messing about underneath.
Postby Brakebuster » Fri Sep 27, 2013 9:38 pm
i have a 54 plate X-Type ,
and from research when looking for the car the sill corrosion issues influenced me quite a bit
it seems that Jaguar knew of this issue and redesigned the sills and braces to stop the collection of water leading to corrosion, so most post 52 plate cars should be in much better condition
pre 52 cars should be carefully examined
Martec
Postby Martec » Mon Sep 30, 2013 8:42 pm
Well I finished replacing the brake pipes with cunifer and all the extra bracket to support it and with my wife pedalling it is full of fluid and working. I drilled 5 holes each side for the sills and used up 2 litres of Dinitrol 3125 cavity wax in every box section I could find under there, approx. 1/4 litre leaked out again.
The sills and exposed painted areas underneath also now have a coat of black wax and I had to replace 6 of the old upper fastenings to refit the sill. the trick is to get the sill in the correct position and gently push until the fastenings can be heard to 'pop' into position (I broke some of them by thumping the sill with my hand).
It was nice to drive it again and a visit to Philip and Tara to get some extra plastic clips to try and fit a support beside the passenger side of the engine bay (the one area the I've not managed to fit an extra support). also it allowed me to shake out a little more of the excess cavity wax.
Now to service the MkII for its MOT before it comes of the road for repairs and re-chroming.
oldtimer
Postby oldtimer » Mon Sep 30, 2013 9:53 pm
Hi Martec,
Pleased you have managed to replace the brake pipes OK. I would have thought a man of your calibre would have taken out both the petrol tanks! I presume you had all the under panels off for that job. I've been tempted to write a comment about removal of the panels beneath the drivers and passenger seat because they collect stones and mud. In particular, the panel is secured by bolts with the exception of two studs welded to the floor with nuts. Care needs to be taken with their removal as it would be easy to shear off the stud if it has not been previously removed and greased. Being a bit of a smarty I have put chrome dome headed nuts in addition to the original nuts, just to protect the ends of the threaded stud. Did you have a problem with these and had much muck accumulated inside.
I haven't seen Dinitrol advertised for years, used to be all the rage. Having said that I have always been a Wax oil advocate. For absolutely no reason other than habit. I'm positive that my old XJ is still in one piece is due to the liberal use of Wax Oil. no doubt Dinitrol would achieve the same
Inhibiting sills seems to be a bit contagious at the moment as I have just done mine and yes a fair amount drained out of the outer cover securing holes along the bottom edge. Having washed all the mud off the sill and found it to be in perfect order I'm doing a lot of hand ringing trying to decide whether to leave as is or apply something.
Just out of curiosity what type of wax injection gun do you use?
Your comment with regard refitting the sill top fasteners is very interesting , I would have done exactly the same as you and given it a whack with the palm of the hand. I have been warned - thanks for that.
Regards Oldtimer
PS Mike K says he takes his hat off to anybody bending below door handle level. I must let him know getting down is a piece of cake, the real problem is getting up again.
Martec
Postby Martec » Tue Oct 01, 2013 8:21 pm
Nice to hear you again 'oldtimer', a number of comments have intrigued me. From my observations and the online manuals the early cars at least have only one tank and due to the hump in the middle to allow the exhausts and propshaft to pass below it then the tank works as two separate wells. The drivers side has the submersed pump and inner reservoir in it and some of the fuel is used to drive an educator in the passenger side to lift that fuel and deliver it to the drivers side!!!!
I would dearly love to drop the rear subframe and get it shot blasted and properly protected, but I'm a bit wary as I don't have the tool to realign it and no idea what it looks like to make one, besides I didn't fancy separating these plastic fittings that connect the hoses to the fuel tank so chickened out on that one as well (old plastic breaks easily).
I had to take down the plastic cover at the rear for access to the brake pipes and as usual sprayed them with 3M plus gas release oil for a couple of days, then used a die nut to cut the rust off the exposed thread and it all came away 'relatively' easily. A tap and die was used to clean them before reassembly with copperslip as usual. I would have liked to have done the fastenings on the fuel pipe side and wheel arch liners, also replaced the fuel filter and a bit more derusting on the edges of the wheel arches, but I'm up against it at present with 3 MOTS to prepare for.
So I drilled holes and cavity waxed and coated the steel sills with under body wax, but it together and drove it to make sure everything worked.
I have used Dinitrol for many years now (we all have our favourites), but 20 years ago I extensively rebuilt my Marina and the MkII Jaguar almost immediately afterwards. Research for underbody protection and rust killing on top was mainly from 'Practical Classics' product tests. I still use Bondaprimer etch primer (a b*gger to scratch off when welding) but the rust killer they recommended will result in a bare metal respray on the MkII due to the reaction. They also recommended Dinitrol instead of Waxoil so I've stuck with these now old products (I used transport black on the bondaprimer but now use crown or dulux black then the dinitrol . I have to say that the underside of my cars is excellent, just the topside is rubbish.
A few years ago I ordered some more dinitrol and mentioned that the give away spray gun wasn't much cop so bought their proper gun (I looked the other day and there isn't a makers name on it) but when given 60psi (should be 30-50) of air pressure it shifts the NEW product very effectively hence the use of 2 new cans of 3125 and the lot was pumped in as any that was kept becomes almost impossible to inject.
Today I used my new Angel Wax (carnuba) to do the topside of the S type as it was so effective and long lasting (brilliant after 8 months) on the 20 year old red cellulose paint on the Marina. I've just been told our old Honda is coming tomorrow for repair and MOT (my stepdaughter's now). I look forward to working on the S type again soon (door locks) I looked at Rogers spares car and the front door locks look simplicity it self to remove.
Best wishes
oldtimer
Postby oldtimer » Tue Oct 01, 2013 8:59 pm
Hi Martec,
Great to get your up date - filled in some interesting gaps.
I agree about the sub frames. I reckon the welders are on a lousy peace work rate cos the weld spatter makes for a rough old finish.
Keep going with those door locks.
I've written an article about electric park brakes for the Mag - don't know if it will ever go to print
Take care
Oldtimer
Martec
Postby Martec » Fri Oct 04, 2013 8:46 pm
Hi Oldtimer,
I know this is now probably the wrong place to put comment, but......... I won an ebay auction for a Tecalamit wheel alignment gauge in Oldham (cheap) and as we needed to burn off 1/2 a tank of fuel, off we went. Picked it up and naturally stopped at IKEA on the way back and then watched the 'milage left in the tank' to see if we could get home with out topping up. We got home with the 'low fuel level' amber alarm on, the fuel needle touching 'E' and apparently 22 miles of petrol in the tank!!!!
Unfortunately I can't get the car into the garage to lower the fuel tank to get the bits of pipe out as my step daughter's car is in there sat at 30 degrees whilst I await the local motor factors to now get our drive shaft reconned as the original supplier can't supply the correct shaft!!!!
I serviced the MkII today ready for MOT and found the brake light switch needs a good shove, so another will be ordered tomorrow.
I'm looking forward to one day having a car in that passes with ease!!!!! silly me.
