Hello.
I have a 2007 diesel S type and would appreciate some advice concerning the rear offside quarter light. The door window moulding (metal part) has become detached. As far as I can make out the moulding is a push fit into what look like white plastic clips. Can any members advise what the part number for these items might be?
My local Jag dealer has given me part number C2S47633010 but when I Google this the part is described as front and rear bumper clips.
Any inputs on what is required and where to purchase would be a big help.
Thank you.
Worried of Woking
(Trevor)
Rear quarter light
Re: Rear quarter light
I am not entirely clear as to which trim part you are referring but Jaguar lists what it calls "M3 plastic pushnuts" for fixing a lot of the S-type side mouldings. They are available under part number XR82170. Hope this helps. Mike.
trevor.pocklington781
Many thanks for your reply Mike. Very helpful.I am not entirely clear as to which trim part you are referring but Jaguar lists what it calls "M3 plastic pushnuts" for fixing a lot of the S-type side mouldings. They are available under part number XR82170. Hope this helps. Mike.
Trevor.
