Wondered if anybody can help, I have a 2002 2.5 V6, when engine is started again after a run, hot air blows from AC when on Climate control, then cold air blows as it should? I checked manual and it says that after use the internal fan should blow after engine is switched off to clear smells etc, could this be malfunctioning?
P.Vickers
