Eurojag would probably help you out of this hole.
Great guys, prices and parts. Most with a short warranty. Expect to pay as little as one third of the new price. That might soften the blow a little.
Brake problem
Re: Brake problem
Pity about that, was worth a try though.
Doug.
Doug.
S Type Forum Moderator
Re: Brake problem
Hello Mike
Had a look at Eurojags and unfortunately they only had one of a late model S/XF and your right it was about a third of the prices quoted elsewhere. The Booster Servo spec was changed in Sept 2005, my car is March, the VIN range covering my car is M45255 to N52047
part No XR843546 . There are 2 different units after mine and 2 before mine. So that's at least 5 different units and that's not counting LHD cars. So when looking to get a replacement great care has to be exercised.
I've just ordered a new (old stock) one from Sturgess Jaguar Leicester on ebay at £390, the last one they say. Just hope I get it, I've messaged them ref delivery but haven't had a reply yet.
Dave
Dave
Dave Hart
Re: Brake problem
Hello All
Well I'm impressed to say the least, the Booster Servo was delivered this morning and it's exactly right
Sturgess jaguar Leicester are faultless!!!. Not fitting yet though it's -6.5 deg outside, will wait awhile.
Dave
Dave
Dave Hart
Re: Brake problem
Hello Folks
Still waiting , got all the bits I need to change the servo but although its a bit warmer it's still minus 2.0 deg outside so waiting a little while longer.
Dave
Dave
Dave Hart
Re: Brake problem
Hello Folks
Just started on Booster Replacement job, First task is to remove the Valance and Engine bay strut located at the lower edge of the windscreen and the strut bolted between the suspension turrets. Job ground to a halt. Couldn't shift the Windscreen wipers at all even using the extractor tool. Thought well I could loosen the valance and get to the retaining bolts for the Strut,it has to come off anyway. Job stopped, unable to get the bolts out. Desperate measures, cut the heads off the bolts and removed the strut. Will solve refitting job when time comes, drill and tap or drill and fit bolts with nut through the existing holes, I can see the floor through the holes. Strut is not in very good condition, its rusted through, in the centre, see photo, obviously through water leakage under the windscreen edge of the valance.
Left the wipers soaking in WD40 for 4 days and tried removal again. Low and behold they came off. Job now put on hold whilst the going is good and I have got a replacement strut, new insulation mouldings for under the valance and cleaned up generally around the rear part of the engine bay which currently is covered in old bits of insulation, mud and general debris
More to follow
More to follow
Dave Hart
Re: Brake problem
Yet another corrosion issue we are seeing with Jaguars of the period. So disappointing. All we can say is that quality is very patchy to say the least.
Re: Brake problem
Hello Mike
The car is now on SORN simply because it wouldn't get through an MOT, due now in fact, with a Booster Servo not working, effectively with no brakes, and in addition some suspension bushes shot. It does give me the opportunity to fix all these issues, including the rear parking sensors which haven't worked for 5 years, through the summer. It's now become a "project car" a bit of a hobby!! The rust issue is a disappointment in a car of this reputation though.
Dave
Dave
Dave Hart
Re: Brake problem
Hello Folks
Just a question, whilst waiting for spares to arrive, re the Vacuum Pump. I note 2 No, take off's from the vacuum pump, one of course going to the Brake Booster servo and the other going to the Exhaust Port Deactivation solenoids. my question is:- would a fault or leak associated with these affect the performance of the vacuum pump and thus the Brake Booster Servo. I assume the NRV in the vacuum tube is there to maintain vacuum at an optimum level in the booster .
Dave Hart
Dave Hart
Dave Hart
Re: Brake problem
The NRV, David. As such it is a non return value. As you infer, it is there to hold some vacuum in the system at all times and avoid a "delayed start to braking" as the system acquired vac suction.
Re: Brake problem
Hello Mike
Yes, I seemed to have answered my own question without realising, you have confirmed. I received the replacement strut (£28.87, new between £115 and £133 for a piece of shaped, painted conduit tube ) on schedule. The minor surface rust described in the sale blurb from "Autoreserveparts" had been rubbed down to bare metal. I zinc undercoated it then gave it finishing coats of Black as per car colour. It looks like new. I've cleared the turret bolt holes for the strut so it's all ready to go back on when I'm ready. Just waiting for Insulation bits from SNG Barratt and I can carry on changing the Booster Servo.
Dave Hart.
Dave Hart.
Dave Hart
Re: Brake problem
Hello Folks
Got the insulation pieces from SNG Barrett, wrong things, I read the assembly drawing incorrectly on their parts finder. What I thought were shaped pieces that attached to the underside of the plastic valance were pieces that attached to the underside of the windscreen bulkhead. They weren’t part of the job I’m doing,I’ve sent them back. As I’m now waiting for some insulation sheet to arrive for cutting, shaping and glueing to the underside of the valance I thought I’d have a look at the vacuum pipe NRV on the spare one I now have. I had previously applied a vacuum to the pipe and found a slight loss through the NRV. I have some Electrical Contact Cleaner so I squirted it in to the NRV, left it for an hour or so them blew it out. A load of carbonised black sludge came out, powdery consistency . I squirted more cleaner in to the pipe until it came out clear,applied a vacuum with my syringe and eureka the NRV held the vacuum perfectly . Question where is this coming from ? . EGR Port Deactivation tube via Vacuum Pump ?.
Dave Hart
Dave Hart
Dave Hart
Re: Brake problem
Dust is probably coming from the reaction and movement between the Spring and Piston/Shaft of the NRV (sorry not aquainted with the exact make up of this NRV) its something I used to encounter with Solonoid Valves and NRV's, when working with Pneumatic systems, sometimes we would coat them with Graphite Powder (nasty stuff).
Doug.
Doug.
Re: Brake problem
What sort of job is it to change the vacuum pump as it looks quite tight where it fits.
Jeff
Jeff
Previous Jaguars.
1967 3.8 S Type.
Series 1 XJ 4.2
Series 2 XJ 4.2
Previous Jaguars.
1967 3.8 S Type.
Series 1 XJ 4.2
Series 2 XJ 4.2
Re: Brake problem
Hello Jeff
A nightmare, it is very tight even after removing all the other bits, wipers,valance ,cross strut, brake servo including master cylinder,engine shielding bits and pieces, it can be done though, the main dealer will give a heart stopping price to do it but a competent diy'er can do it according to the Workshop Manual.I have the JEC Maintenance disc for the S-Type and it describes in there how to do it. I am hoping with everything crossed that mine is serviceable, I've ordered a Vacuum Gauge to see (from China) if mine is up to scratch as a cheaper option initially, if not for £25 the gauge will come in useful as it's part of a brake bleeding kit which I have to do anyway. I now have a secondhand vacuum pump from eBay £30, from Harvey Taylor Vehicle Management with assurance that it was in good working order when removed from a scrapped 2006 2.7d S-Type.
(£628.76 pus VAT,plus seal at £21.78 plus VAT , from SNG Barratt) You don't want to know the Jaguar dealer price.
Dave Hart
Dave Hart
Dave Hart
