Sidelight Upgrade
Posted: Fri May 29, 2015 12:10 am
Having the HID lights on my car I have always thought the sidelights look rather yellow compared to the dipped beam. This week I finally ordered some CAN bus compatible LED sidelight bulbs and I'm pleased with the improvement as you can see below.
I purchased the bulbs from ebay.
The sidelights are quite fiddly to remove, so make sure you test the bulbs before putting them back into the headlight fitting. Being LEDs I'm assuming they only work fitted with the correct polarity? Typically, when I fitted them first time around both didn't work, but I quickly worked out why. Removing the sidelights again I was able to insert them the other way around and both then worked.
Before
After
Steve
Before
After
Steve
