Front Offside Fog Light Replacement
Evansmr
Postby Evansmr » Sat Jan 11, 2014 7:06 pm
I need to replace the front fog light, off side, after it and the surrounding plastic cover were damaged when I hit an obstacle in the road. It is true I don’t use them much but for the looks want to replace it.
The fog light has 4 screws which need to be tightened from behind and look a devil of a job to replace and if you have any tips on how to replace it I’d be grateful.
Martec
Re: Front Offside Fog Light Replacement
Postby Martec » Sun Jan 12, 2014 1:38 pm
You don't say if your car is pre or post 2002.5 as they had different front 'bumpers/spoilers'.
If its the old style bumper, then if you jack it up and support it you can remove the black plastic underskirt and all is revealed, access looked very good when I last looked. I don't know about the new type bumpers.
Best wishes
