Headlight self levellers
foss16
Postby foss16 » Tue Jan 19, 2016 6:00 am
My headlights now shine no further than a couple of feet in front of the car. The self levellers appear to have given up the ghost. I've seen on youtube that you can fix them in place with a screw between the 2 headlights, but I'd prefer if they worked properly. Any clues of how to fix them please?
Re: Headlight self levellers
Postby J44EAG » Tue Jan 19, 2016 2:33 pm
It does sound as if the leveling devices have failed.
There are a few repair kits around on ebay and other internet sites. Worth a trawl to see if you can get the replacement parts.
I recall Dave Marks has a fix for these units. Drop him an email and ask for his advice.
Otherwise it is off to a breakers yard or a phone call to Eurojag. There prices are reasonable. and service excellent.
foss16
Postby foss16 » Tue Jan 19, 2016 10:08 pm
Thanks Mike, I'll give your suggestions a look
Montana5
Postby Montana5 » Tue Jan 19, 2016 11:07 pm
Replacement adjusters are available on e-bay, not an easy job to replace though, or just do the screw fix and they will self level again, its what I did 5 years ago.
Doug.
S Type Forum Moderator
foss16
Postby foss16 » Wed Jan 20, 2016 7:17 pm
Thanks Doug. I'd seen that on youtube but didn't know if anyone had tried it
jeff1954
Postby jeff1954 » Thu Feb 25, 2016 8:17 pm
Hi Has anyone got the youtube link and would the fix work on Zircon lights?
Jeff
Previous Jaguars.
1967 3.8 S Type.
Series 1 XJ 4.2
Series 2 XJ 4.2
Montana5
Postby Montana5 » Fri Feb 26, 2016 10:51 am
This is the screw fix video I did on my Car with Xenon Lights, if that's what you mean...
https://www.youtube.com/watch?v=rFRqWMX4okw
Doug.
jeff1954
Postby jeff1954 » Fri Feb 26, 2016 6:34 pm
Thanks for that Doug God knows where I got zircon from, senior moment I expect. So when that screw fix has been done do the headlights self level as normal.
Jeff
Previous Jaguars.
1967 3.8 S Type.
Series 1 XJ 4.2
Series 2 XJ 4.2
Montana5
Postby Montana5 » Fri Feb 26, 2016 9:45 pm
Yes Jeff.
Doug.
jeff1954
Postby jeff1954 » Sat Feb 27, 2016 5:31 pm
Done today, took about 10 mins
Thanks once again Doug.
Jeff
Previous Jaguars.
1967 3.8 S Type.
Series 1 XJ 4.2
Series 2 XJ 4.2
horatio597
Postby horatio597 » Sat May 27, 2017 1:44 pm
Hi there
Looks like I've got a NSF fog lamp bulb gone. Is it a simple job and how would I go about replacing the bulb? I can't decide which is better because of the large variety of led fog lights kits.
The OPT7 bulbs appear to be high quality.
Which fogs will fit normally to my car? Thanks in advance for any help.
Postby J44EAG » Sat May 27, 2017 2:12 pm
You should be able to find the lamp type, ie H2, H7 etc in the drivers handbook.
jeff1954
Postby jeff1954 » Sun Jun 04, 2017 2:33 pm
horatio597 You will have to remove the cover underneath the front bumper to access the rear of the fog lights to change the bulb. It can be a bit tricky if it has not been off before as the fixings can be seized up.
Jeff
Previous Jaguars.
1967 3.8 S Type.
Series 1 XJ 4.2
Series 2 XJ 4.2
