What is this?
robertwilsher67886
Is this the connection to a pump or a sensor?
Re: What is this?
A better quality photo would help. The pump should also be visible if the connector is for that, the sensor connector is slightly higher on the tank.
robertwilsher67886
Re: What is this?
Thanks… I just thought someone who has worked on one of these would know….
I want to put a direct 12 volt feed to it to check the pump is working if that’s what it is…if it’s a sensor that’s the last thing I want to do…
Re: What is this?
Pretty sure the pump sits on the tank not in it, so I think that's a sensor?
XF Sportbrake 2020 / XK8 1998
