Boot opens every time I unlock the car.
Flappers
Postby Flappers » Thu Apr 15, 2021 4:46 pm
Hello again, so ever since we had a super hard frost every time I open the door and release the central locking the boot pops, same when u open the car via the fob. My local shop keeper finds it highly amusing each time I pull up for a bit of milk or something and I get out only for the boot to open :D Any thoughts anyone please?
Kind regards, Sam.
1989 Daimler Double Six
2002 STR
Flappers
Re: Boot opens every time I unlock the car.
Postby Flappers » Fri Apr 23, 2021 9:37 am
Can anyone help please?
Kind regards, Sam.
2002 STR
jeff1954
Postby jeff1954 » Fri Apr 23, 2021 6:12 pm
Sam have you got a second fob that you can try. If it's still the same with that try a battery disconnect for 15 mins. Make sure you have your radio code before doing the latter.
Jeff
Previous Jaguars.
1967 3.8 S Type.
Series 1 XJ 4.2
Series 2 XJ 4.2
Flappers
Postby Flappers » Tue May 04, 2021 8:40 am
Hi Jeff, I tried disconnecting the battery with no luck and haven't tried the other key fob yet. The boot will open as I open the door from inside after moving the car and it locks itself.
Kind regards, Sam.
2002 STR
Andy P
Postby Andy P » Tue May 04, 2021 11:26 am
Hi Sam,
Have found this thread on Jaguarforums which might have a solution for you:
https://www.jaguarforums.com/forum/s-ty ... red-31074/
Post No 7 seems to have an answer but read the whole thread as it gives another possible cause.
Hope you get it sorted,must be so frustrating for you.
Good luck.
Andy :D
