s type none function of kick down
Posted: Tue Nov 22, 2011 11:47 pm
by robertxkr1
Hi have a 3.0ltr 04 auto ,vehicle changes gear under normal usage but kick down does not work,is this a common fault also is it a reasonable repair, regards robert.
Re: s type none function of kick down
Posted: Wed Nov 23, 2011 12:20 am
Hello Robert.
I`ve personally not heard of a kick down failure before but having just done a little research I`ve come up with these two prominent fault codes.
P1306 is kick down relay, pull. In circuit fault.
P1307 is kick down relay, hold. circuit fault.
Both of these codes if found could provide a possible lead if itemised by electronic diagnosis.
The only realistic way of finding what is truly at fault is to have the car electronically diagnosed preferably at an independent Jaguar specialist, a Main Dealer or a transmission specialist. Otherwise it is pure guess work.
Please let us know what you eventually discover.
Posted: Wed Nov 23, 2011 11:24 am
by robertxkr1
Hi Mike
thanks for info, yes guessed i would have to go to dealer, wife is going to be happy !! ive got my 99xkr (baby) in workshop after accident. Oh also forgot to tell her she will look a bit different when she comes back,got a wide body from zeemax being fitted oh and s/s exhaust . oops!!!! :twisted:
