Postby J44EAG » Wed Apr 09, 2014 12:36 am
This subject has rattled around since the S- first saw light of day.
Jaguar motted "filled for life" not "sealed for life" How long is "life"? The owners manual says words to the effect of "or when the car is used in harsh conditions" oil should be changed. All rather contradictory and somewhat confusing. Quite what defines harsh conditions is difficult to quantify.....
Oil changing for S-type gearboxes is not on the service scheduled. Not good. So dealers don`t do it unless asked to so do. Madness in my opinion.
Those of us who have had to have reconditioned gearboxes fitted will be aware that if failure occurs, one is faced with an invoice of £2000 upwards. Oil ages, oxidises and breaks down due to the effect of heat and pressure. So if we are wise we change the oil at regular intervals. Not to do so will eventually result in failure. Changing oil is done as a preventative measure to help extend the life of a transmission. To ignore that will lead to a shorter service life.
I bought my first V6 S-type when it was six years old. At that time i attended the first JEC seminar and was appalled to learn about the regular instances that Club members had as regards modern Jaguar transmission failure. That included XJ8 and XK8 models. It became very apparent that oil changing had to occur to preserve the life of a gearbox and the subject became a regular item in our magazine. At that time the subject was also debated at length on these Bulletin Boards and we all learned the good sense in oil changing.
Those of us who are familiar with the issue would not ignore the need for having transmission oil changed. It has a service life which when expired will progressively lead to a transmission failure. Best advice is to take a car directly to a local transmission specialist and have them do the job. Expect to pay around £400 for a full flush and refill which should include oil being changed in the torque converter and oil cooler. Anything less is only half a job.
I am surprised to learn after all these years that some Jaguar dealers may still not be undertaking oil changes. To my knowledge the wisdom of oil changing did eventually filter down to dealer level and become accepted practice.
Most dealers will not do gearbox oil changing themselves. Expensive and complex oil change machinery is involved and many will simply sub a car out to a gearbox specialist and charge you a premium for such work.
For further information on this subject, look in the gearbox sections of XJ8, XK8 and S-type Bulletin Boards. You will find a huge amount of information about gearbox oil changing on these boards and find a common conclusion being reached.
