Differential bolt
Posted: Sun Jun 23, 2019 6:51 pm
by Filmdori
Hi all
I have lost one of the mounting bolts from the rear of the differential. Does anyone know the type of bolt required or where I can get one.
Dan
Re: Differential bolt
Posted: Sun Jun 23, 2019 11:02 pm
Possibly a Main Dealer or perhaps second hand from Eurojag or Auto Reserve.
You may also be able to obtain one from a local bolt supplier if you take one you have in the diff for evaluation.
Posted: Mon Jun 24, 2019 4:47 pm
by jeff1954
Yes I would go for Eurojag they will have one, have you dropped the sub frame because when I swapped the Diff over on my car the bolt's don't come all the way out. So if you have make sure you put the bolt's through the sub frame before positioning it on to the underside of the car.
Jeff
Posted: Mon Jun 24, 2019 9:45 pm
by Filmdori
I'll give them a call.
I had the diff changed last year but the bolt came loose and dropped out it seems. Or its snapped.
