Here is the bottom tensioner arm complete with the pulley and internal bearing. The link is useful as it gives the part number as well for quick reference.
http://www.ebay.co.uk/itm/JAGUAR-BRAND- ... 1c48866d5e
Note the 3/8" square drive hole into which you fit a square socket drive on a long ratchet arm when you wish to de-tension the serpentine belt for replacement.
The pulley can be replaced separately if the bearing becomes worn. I`ve yet to find the replacement bearing in the open market but in any case good second hand pulleys are around for about £10. The pulley is fixed to the tensioner arm by a 13mm central bolt and a large, thick washer. The bolt and washer removed, the pulley slides off the tensioner mounting pedestal. Not a difficult job which can be done leaving the tensioner bolted to the front of the engine.
The upper fixed idler pulley adjacent to the water pump is very similar in arrangement but is fixed in location. Similar mounting pulley arrangements will be found.
The tensioner and pulleys are fairly bulletproof in service. Failure is very rare although some bearing noise may accumulate at advanced mileages.
