Oil leak from rear of Inlet manifold?
Posted: Mon Sep 08, 2014 12:32 pm
by fdy130
I have an interesting little oil leak from the rear of the inlet manifold on my V6 petrol S Type (2001 model year). There is a squareish black plastic piece at the bulkhead end of the manifold with some sort of electrical connection in it. Held on by four small bolts. This seems to be weeping oil (no noticeable impact on oil level) onto the exhaust manifold while parked. If you stop after a few miles smoke rises from the rear of the bonnet, which is a bit disconcerting! The oil burns off on a long run and the problem disappears until the next start up. Is this a common problem? How easy would it be to fix? I have taken a picture but it is not very clear
Re: Oil leak from rear of Inlet manifold?
Posted: Mon Sep 08, 2014 10:20 pm
One for Martock to answer I think. He has had a V6 in pieces recently and knows his way around these engines.
Posted: Tue Sep 09, 2014 4:54 pm
by Martec
I looked at this yesterday and couldn't understand what it was about so waited for those learned in S type matters to answer.
I've looked at our S type inlet manifold and tried to find the spare one (no idea where it is), but seem to remember that this is one of the variable air baffles (open or closed dependant on engine revs). undo the two 8mm headed bolts and carefully prize it out and I think it is only sealed by an 'O' ring.
I believe the only oil anywhere near this is from the crank case breather (a rectangular box bolted to the back of the head and a pipe running forward to the inlet manifold after the throttle body there is also a line from the cam covers that puts CC pressure into the duct before the throttle body (hence the throttle body getting filthy inside).
If oil is leaking out then air can leak in! is it leaking from the large seal ('O' ring) or through the electrical connection? on the variable baffle.
It may just be a matter of removing the connection, remove the two bolts and carefully lever the baffle thing out and replace the seal (there is no separate seal show in the drawings so I assume it is stuck to the plastic baffle housing).
