Diesel injector sleeve clean up tool. Leak free injectors.
Posted: Mon Apr 28, 2014 7:14 pm
Those of use who have occasion to work on diesel engines will be aware of this frequent issue.
I`ve lost count of the times I`ve rebuilt diesel engines and struggled having removed diesel injector from a cylinder head only to find that despite cleaning up injector and copper seal sleeve faces, the wretched injectors "chuff" slightly once an overhauled engine is started. Combustion gases leak past the injector sleeve and injector on the compression stroke and fuel leakage can also be a nuisance. The problem is usually that the copper sleeve seal in the head becomes marked or distorted causing an injector not to seat and therefore seal correctly. An excess of old difficult to remove carbon combustion by-product can also be encountered.
"Chuffing" injectors are a pain. Having built up a diesel fuel system once, it then has to be broken down to cure the issue and then built back up again. With this kit now in stock, I can ream sleeve seats before installing injectors at rebuild stage and do not have to take the risk that my work will be spoiled by leaky injectors.
I`ve promised myself a sleeve reaming kit for years. Now thanks to ebay and the Chinese tool revolution I have one for £23 delivered. The kit comprises a T-bar, a common reamer mandrel with dummy injector nozzle guide, five common sized reamer heads and an Allen key used to fit a reamer to the mandrel. Years ago and before the internet and ebay made cheap tools easily accessible, one would ether have had to have the sleeves professionally attended to or one hired a tool or paid and arm and a leg for an expensive trade tool. For us we are definitely on a winner when it comes to the current way we can buy what we need at affordable prices. To use, one selects the appropriate reamer, fits it to the mandrel and places a little grease on the cutter head. The cutter is lowered into the injector sleeve and the T-bar is turned to remove copper from the sleeve base. The copper cutting swarf is held by the grease to ensure that it is removed from the sleeve and does not find its way down into the combustion chamber. The secret is to only remove as much copper as is required to produce a decent flat unmarked surface. A rag and screw driver are carefully used to remove any remaining detritus before an injector is refitted to the cylinder head. Carried out carefully, one should end up with a leak free injector. What is next on my wish list? Possibly a broken spark plug removal tool and a taper seat spark plug renovation tool. Useful for petrol engines.
