On a different forum I have been reading about a process called Terraclean which claims to remove carbon build up from older engines. Has anyone in the Club used this? Good results?
Seems to be providing good results based on views across the 'net, but would appreciate your input. For those who have not heard of it, see here, fast forward to 6.30 for the cleaning bit:
http://www.youtube.com/watch?v=iQNSCnpx ... q2JIyXRE56
Terraclean
Equalizer
Re: Terraclean
No-one used this or read about it or have any opinion on it? No-one from the technical team care to comment?
Re: Terraclean
I was looking at the Terraclean site the other evening and also at some blog sites which had comments about the process.
Seemingly, results are good generally. Many people report a huge drop in hydo carbon output after the treatment and also a slight performance increase. There would seem also to be a fuel consumption improvement also after cleaning.That I am quite prepared to believe.
Am I considering having my car given the treatment? Short answer. Yes.
Two treatment types exist. One for diesel cars and one for petrol vehicles. On the blog sites there existed some cautionary posts regarding treatment of some diesel units. Namely diesel Ford Mondeo and Jaguar X-type models. Apparently there can be some detrimental effect to injector seals. The moral of the story then would appear to be that if you have a diesel car which you wish to give the treatment, to check with Terraclean to ensure no detrimental effect would be likely.
Before committing J44 to the process, I need to just check my last MOT emission results to see just how dirty my car is. Ed China`s car I recall was quite dirty at around 550pmm. That dropped markedly after the process had been run.
Effectively the process is a fuel system clean and condition combined with an internal engine decoke. That such a process is possible at around £100 leads me to think that such maintenance at quite a reasonable price can`t be a bad thing.
I remember that at one time there was a process which used egg shells as a blast medium. The idea was that you could remove inlet and exhaust tracts and blast clean valves without further dismantling of the engine. The blast material could then be vacuumed out leaving clean cylinder head tracts. Bolt the manifolds back on, and off you went with a minor clean up achieved. Although only a partial engine clean I imagine the process could be quite beneficial. terraclean is obviously a far more advanced process than that.
Equalizer
Re: Terraclean
I have been reading that a contrary opinion is to merely use petrol like Shell's V-power which is claimed to clean you engine as it drives anyway. OUt of interest, yesterday I emailed Jaguar and asked if they recomended using V-Power (Ferrari do!) and if they have tested or recomend Terraclean for older vehilces. Their reply is as follows:
"On your behalf I have spoken to our Technical Engineers who advised the following:-
Octane rating 95 RON unleaded as a minimum -
98 RON may be used as an occasional alternative - but revert back to normal unleaded.
With regard to the Terraclean process, no recommendation can be made as this is not something that Jaguar has tested and therefore unable to comment.
Please do no hesitate to speak to one of our Jaguar franchised dealers should you required confirmation or any other technical information.
Yours sincerely
D Lonnon
Jaguar Land Rover Limited"
That seems to be clear that ordinary fuel is good enough!
Still feel that using V-power and possibly using Terraclean would benefit an older car.......
Any other opinions or experience out there?
Yours sincerely
D Lonnon
Re: Terraclean
I can only recount my experiences on my V8 as regards fuel rating and performance differences.
Originally, my V8 S-type was a stock production unit fitted with a standard engine. Whether I used ordinary unleaded fuel or super unleaded, drivability remained the same. A small reduction in fuel consumption occurred when using super unleaded. The small economy gain did not offset the extra cost of using the super unleaded.
However once I had the ecu reflashed, fitted a decent air filter and a big bore exhaust, the difference when using normal or super unleaded became noticeable. Most certainly noticeable in town when pulling out onto a roundabout from a standstill on standard fuel, the engine is a tad slow to pick up from stationary. Running on super unleaded sees this minor issue disappear.
Most noticeable on the open road is an increased urge and instant response to the throttle when using super fuel. The car seems to pull for ever. On standard fuel the car is nowhere near as ferocious. Around town on super unleaded and on light throttle, the car drives as if it were running on quick silver. Again on super unleaded a minor fuel consumption occurs but the cost of the super fuel does not gain or create any financial economy.
I use ordinary fuel around town and super fuel for long fast runs on the open road. It is difficult to comment on whether one fuel harms an engine more than the other or if using super grade fuel in fact cleans an engine better than the standard fuel. Higher octane can increase combustion chamber temperatures which can lead to a degree of minor carbon burn off. Thats about all my experience can offer in comment I think.
- raysearles
Re: Terraclean
The merits of V Power or any of the other brands of "extra" fuels have often been debated, sometimes vigorously on these fora. The reality is that whilst Shell and others will make claims that these clean your engine better, the likelihood is that one tank in say 10 fills is unlikely to make that much of a difference.
Some members swear that they get better economy and performance after using these more expensive fuels, I am afraid as the ultimate "cynic" I think this is just what we humans do when we buy into something and then convince ourselves we are benefiting.
The reality is no two journeys or tanks of fuel are ever the same so to be able to say absolutely that these products make a real difference is extremely difficult - but as I say some owners will use nothing else.
In the end like so much in the modern world - you pays your money - you makes your choice....
Re: Terraclean
If I may add my pennyworth, the engine in the video was very dirty as the emissions showed, so it had been treated poorly. Not replacing the plugs and coils when necessary and possible misfiring, probably not have sufficiently frequent oil changes. The terraclean appeared to remove the muck and reduce the emissions, but were the underlying issues also sorted?
If we have an engine that is well within the emissions limits and so probably well looked after is such a radical treatment necessary or wise? Frequent and regular oil changes, use of the gentler extra cleaning of 97 octane fuel from time to time seems a better option to me.
Re: Terraclean
Just out of interest my 4.0 XK8 that has covered 106,000 miles had a HC ppm of 4 at the last MOT - I run it on V Power all the time and give every tank full a shot of Redex seems to work OK for me i feel
Ian
Ian
Re: Terraclean
Ray
My experience with my last car over 20,000 miles or so was that Shell V power gave a 1.5 mpg increase in performance (26.5 to 28.0) over "ordinary" unleaded.
I take your point tho, we believe what we want to believe!
Having said that, I NEVER fill up at Supermarkets....I do think their petrol is not of the best refined quality, ( with regard to the latest additives) hence it is cheaper.
TonyS
TonyS
XJS Bulletin Board Moderator
johnnewzealand
Re: Terraclean
Hi.
Interesting comments regarding Tetraclean and fuel grades used. I'm a marine seagoing engineer (Chief Engineer), so not a car mechanic etc., but, can definitely confirm that fuel additives and conditioners most definitely work well in marine diesel engines, e.g. keep injectors, valves, etc., in good condition. BUT, they don't eliminate the need to still service these items regularly - they DO keep the engine (in general) in "peak" condition between services etc., therefore are economical and good for engine long life, but, as said, they don't eliminate, or prolong, the recommended service intervals.
Tetraclean seems to be a reasonable way of getting a "tired"/"neglected" engine back into reasonable shape, but won't (in my opinion) fix inherent problems that may be there from a lack of regular servicing. My opinion? - yep, get it done if you have a car with an unknown service history, sounds like it can't be bad, but if you've had your car serviced regularly, or have a good service history, it's probably not worth it.
Regarding fuel - I can only comment on my S-type. A 2001 3L petrol that I've owned since 2006, and now has 240,000kms on the clock. I bought it with 87,000kms on the clock, and the service book filled in at the correct intervals (16,000kms). I have had it serviced every 16,000kms. by the Jaguar agency, and have had NO problems whatsoever! It hasn't been cheap! I've had everything done that was required, mostly at my request, e.g. spark plug renewal every 50,000kms., coolant & brake fluid change every two years, etc. etc. BUT, engine oil is still only slightly discoloured at a due service. I have ALWAYS used 98 Octane fuel (5% Ethanol in New Zealand), very occasionally I put 95 Octane in, perhaps what you in the U.K. call "super" - "normal" 92 Octane I NEVER have put in. All fuel in N.Z. is unleaded by the way. Most people use the 92 of course -it's 10cents cheaper than 95. I do realise I'm lucky in being able to afford to put the top fuel grade in my car, and to have it serviced regularly, but, it does indicate that "pampering" a car does work in the long run.
I do so, i.e. "pamper" my car, because I love my 2001 S-type. I have many times thought about "upgrading" to a later Jaguar, I'm lucky enough to be able to afford to, but really don't see any reason too! I love the S-type!
johnnewzealand
Re: Terraclean
I posted recently about a product I`ve used recently to help keep catalytic converters clean and emissions to their minimum.
The product is Cataclean which can be found on ebay or at many motoring stores or trade outlets. About £12 for a 500ml bottle which is poured into a quarter tank of fuel and the car then driven.
My HC emission at MOT time has been around 80ppm for years. The pass for my V8 is 200ppm. The Wheeler Dealer, Ed China XK8 was very dirty indeed at 550ppm. That car really did need a good sort out. As mentioned previously the Terraclean process was used and proved most effective.
I bought a bottle of Cataclean and added it to the fuel and drove the car. A couple of days later the car went for MOT and passed with flying colours. Just 1ppm now being recorded.
The product can be used to attempt to clean cats which have flagged up a fault code. Given a bit of careful driving following treatment the additive has been known to clear a partially blocked cat and extinguish the MIL lamp in the process. Suffice to say that if you find yourself with a cat induced fault code and you are told the cat needs replacement, it is well worth trying this product before you shell out for a new component. If it works for you and fixes the issue, you will be quids in. Also rather cheaper than a Terraclean process which in some cases the cost of which may not be necessary.
Re: Terraclean
In addition to the above comments I think that modern electronic ignition systems are specifically designed for modern fuels as you would expect and although they could be refined to better match the exact particulars of a car they generally do a good job.
For instance my Mercedes A45 AMG is a 2 litre car and is designed to run on super unleaded. This gives a power output of at least 360 bhp. If super unleaded is not available you can use ordinary unleaded and the electronics compensate but power is reduced and it is advised not too drive it too hard. I have had to use ordinary fuel and you do notice the significant difference. The car actually runs slightly cooler (both oil and water temperature) when on super unleaded but I am not sure of the actual situation in the cylinders.
The electronics are all too complicated for me and that is why I enjoy running and working on the Jag!
Paul V
Mk2 3.8
Nissan Micra K13
Porsche Macan S
Mk2 3.8
Nissan Micra K13
Porsche Macan S
