It would seem I have to admit to being a complete idiot and have run a big end on my 3 ltr V6.
When I heard it, it sounded like a big end but hoped it was something else and almost convinced myself it was the dual mass flywheel, but talking to Phillip and then to Ken Jenkins and a 'David Bye' it seems it is quite common on X types and less common on S types. Daft as it may seem a second engine would be cheaper than a new flywheel and clutch!
Apparently running the oil low is a common cause of engine failure, as my oil is between the marks, I looked for another reason and it seems my oil filter is too small. the car came with this size fitted and I have replaced the same size filter twice now, but it is for a 1.6 ltr engine. I have the bigger size now (a bit late).
So tomorrow I'll drain the engine oil and see what is in it, either way I can't see an alternative to removing the engine and box and start stripping it all down (over size bearings are available for a reground crank).
An idiot with a duff engine!
Re: An idiot with a duff engine!
Oh dear, how sad - I feel for you; if anyone has had the dreaded rattle it is something which is never forgotten. At least you can repair it at your leisure. Mine went on the newly opened M1 when I was on my way back to RAF High Wycombe in my shiny red Dellow wth Ford 10 sidevalve engine, cruising nicely with no other vehicle in sight (can you believe it looking at the M1 now), when far behind in my mirror appeared a speck which gradually overhauled me and became the first of the new Minis I had seen. It slowly passed and I thought "I can keep up with that", so accelerated only slightly and kept it in view. After about ten minutes at that speed the death rattle came, but I dare not stop as I was due on duty and non appearance meant a charge, no excuses, so I backed off and found that on a very light throttle the rattle was not too bad.
Come to the Club next Monday and cheer yourself up a bit with the quiz.
1994 Coupe AJ6 engine
Hi Paul, 3 solid days of finding and separating all the connections ready for lifting (seized exhaust nuts and these daft spring clips for the hoses have been the worst).
This morning bright and early with the help of my grandson and a friend we lifted the engine, but couldn't get it out of the engine bay due to the long nose on the sump touching the radiator. It is back sat on its supports until Monday when I will have time to find out how to remove the radiator, but leave the A/C rad in place.
These are several firsts for me, never blown an engine before, never spent 3 days preparing to lift an engine (other than a rather large V8 generating set) and never failed to get an engine out at the first attempt!
Better luck next week.
Hi Martec,
Sorry to hear about your plight. At least it'll take your mind off door locks!
I have been agonising over your engine problem since reading about it. Based on what you wrote with the oil level between the prescribed marks and an under size filter I find it difficult to understand why this failure arose.
Oil filter assembly design used to accommodate a blocked (very dirty) filter bypass feature. This allowed the engine to operate on un filtered oil. When the filter became blocked oil pressure lifted the filter element by compressing a spring and allowing a by-pass.
My first question would be, is there a bypass feature in the modern spin on filter? I just cannot remember - never mind - cut the old one open and have a look. Also examine the filter head for a bypass.
I would be disappointed not to find a by-pass. If there is one, the filter size would not make a "toss" of difference in these circumstances.
Martec, You did not mention the total mileage. I shall be very interested to hear what the crankshaft measurement are.
It would be sad to have a second failure because the original fault was not identified. I'm sure you will examine the oil pump and pick up pipe and all associated bits. Wish I lived closer to help
Back in my Warranty days a range of Cam shaft kits were available. From time to time, shortly after fitment a Warranty claim was submitted for our crap Cam kit. Further investigation would reveal that the original problem still existed in terms of no oil pressure. This, as was frequently the case, the problem was down to poor diagnoses or fitment. Dare I mention it -also brake discs
I'm sure you will keep us up to date with your findings
Oldtimer
Oldtimer
We are both thinking along the same lines 'Oldtimer', why did it run a big end, when I can get at it I hope to find the cause.
It is a MY2000 car L83,--- vin number, at 97,3-- miles. I thought of not much else other than what did I do to create this problem. I was out on a back road giving it some stick over rough roads to find out what symptoms were evident when it wandered. I pulled out to overtake a van and trailer and in 2 nd gear hit the rev limiter. 5 miles later at Philip and Tara's scrapyard I heard the dreaded rattle. I do have a habit of underestimating the bottom end torque or lack of it and stall it so I'm wondering if that has anything to do with it as well.
Today I tried in vain to remove the radiator through the top of the engine bay so decided to cut off the two large mountings for it on the front steel cross member, it fell out. So I'll make up some new brackets to be bolted on, but I can have another attempt at lifting the engine tomorrow except I'll be on my own as my two helpers are otherwise engaged. The boss will be my eyes for any item interfering during lifting.
Thanks for your interest.
PS a new oil pump is on the cards anyway and the relief valve inspected (no oil light came on so it must have been above 5 psi).
Brian,
Originally the engine went in from below. That means a subframe and suspension strip out if it has to go out the same way it went in. Hopefully you can get it out upwards. Otherwise you might have to go out from below.
These V6 units are now beginning to fail regularly. I now know of around six that have all failed from similar issues this year alone.
Generally I would point towards oil starvation. I`ve known one unit where a big end shell from the rod cap rotated and jammed between the crank and the upper bearing in the con rod.
A good oil changing regime helps but as Phil says, jammed PRV units can cause havoc.
This sort of damage should be fairly rare given that modern oils are so much better than the old mineral types. Clearly, in my opinion, despite technical advances in lubricants and more stringent adherence to regular oil changing, these issues still rear their heads. Sadly, the V6 does regularly suffer a starvation issue.
Daft as it sounds Mike that is good news, I 've joined the ranks of other poor s!ds and I may not have caused it.
The guy I spoke to said the 3 ltr failures were common on X types and less common on S types but he had seen a few. The Duratec is supposed to be a 200,000 mile engine, and the bores seem to be, but is the rest of it good for 200,000 miles? Maybe it doesn't like being hammered!
I'll have to go back to my Marina, a 1.8 'B series block with a mondeo cylinder head, full EFI which gets a regular thrashing and is still in one piece (a zetec engine and sierra gearbox awaits the final failure).
Update,
With the bosses help the engine came out the top and was landed on another of my engine trolleys with an hour. I've been removing ancillaries to make room for the rotisserie arms to turn it over. Gearbox off tomorrow and a look at the clutch and flywheel??
There's good news and bad news, the clutch and dual mass flywheel looks brand new, its not been in there very long.
Bad news, No5 big end shells have been rotating in the con-rod, no2 big end next to it is perfect. I've to open up all the bearings to see what state they are in but on the basis of those two bearings it could be machining tolerance for the shell to slip, but at 98,000 miles!!!
Now to find the cost of machining the crank, shells, con-rod, piston rings, piston, possible chains and tensioners, seals, gaskets and head bolts............ouch.
Edit:- the other top shells are all worn and need replacing anyway.
Hi Martec,
I'm still agonising over your engine dilemma. Both you and Mike K have related conversations of big end failures on both S and X types. This I find a bit worrying but when you consider that about 200,000 3Ltr V6 were produced and probably a similar number of X types then as a percentage the failure rate is 2/5ths of naff all.
A recent survey by the AA claimed that only 11% of those asked, knew how to open the bonnet. So, of those failures how many simply ran out of oil?
It's so easy to give a dog a bad name, in that, of all the recorded failures no central organisation analyses the defects to give a true picture.
In respect to your engine failure you tell us that the remaining shells show signs of were. This indicates to me signs of a very mature engine. I find it difficult to believe that there was a machining tolerance problem in the connecting rod. ( I've just been looking for a book that has engine oil flow figures in that I could quote as a example but can't find it) With the introduction of the crescent type oil pump( stolen from automatic gear box design I believe) wrapped around the front end of the crankshaft the oil flow rate is unbelievably high. I won't quote a guess figure, the point being that these high flow rates serve as a cooling medium as much as lubrication. One has to consider the effects of a worn engine in respect to both oil flow and pressure. You tell us that you accelerated in 2nd gear up to the rev limiter what ever that limit is. Do you think it could possibly be that your over exuberance was a rev too far?
Do keep us up to date with the progress
Oldtimer
PS I was just thinking about all those jobs you could do while the engine is out !!!!
Oldtimer
Hi Oldtimer,
What caused the shells to turn is not known, as the history is now destroyed, journal 0.4mm flat on one side, one shell now welded to the upper con-rod half. I drove the car at least 10 miles with the failed bearing and the metal soup of steel and white metal did for the other bearings.
Like anything else I accept responsibility for the failure as I was driving at the time (you can see I would never make a politician).
I've had time to think about this failure and can remember several times when at start up there where some strange noises from the engine which I initially thought were drained down hydraulic tappets and a light rev of the engine cleared that. But they are solid tappets and everything I have found on the top end is perfect.
As I have said bar room talk says the V6 when fitted transverse will fail with oil starvation!!!! that would required a run around Garrard's bend at Mallory park (done that in the Marina, limited to 50mph due to massive oversteer with the back end hung out).
Talking to machine shops about the modern engine (I'm used to the old BL 'B' series and Jaguar XK engines) it would seem that they don't fit a set of 'standard bearings' but bearings that fit that particular rod and journal. The oil is thinner now and the clearance a lot less. A friend of mine who is into bikes says the Japanese have been sizing their plain bearings for years.
The only thing stopping bearing shells turning is the nip of the conrod bottom cap, not the little locating lugs on the shell (even these are different now). So for me the only way a shell can turn is if the conrod gets hotter that it should, or the fit was below tolerance in the first place.
As you say we have no history of second hand cars, and I know a man who thinks I am a fool (Ok more than one!) because I change the oil and filter of our cars and those of friends at least twice as often as the manufacturer says (he only tops them up when found below the minimum mark).
Yes I have enjoyed driving the car on the local Lincolnshire roads quickly, but less so than the Marina or MkII due to its size and weight (I've hit the hard cut limiter on my bastardised Marina engine more times than I care to remember due to the low first gear).
In all honestly I think I 'bought a pup' (not the first time) and my driving style finished the engine off, I have been consistent in oil changes but have the previous owners?
As it is usually a rotten body shell that scraps a car and ours is very good and now injected with Dinitrol wax, scrapping was only a passing thought. Also like Mike I have invested a lot of time and effort into this car ie the electronics, door locks, alignment and brakes so a duff throw away engine will only slow me down.
A machining company I spoke too said these 'Ford' V6 engine (I thought they started life with Mazda??) are force feed in Noble cars and when a crank runs a bearing it bends the crank and it is scrap. They would check the crank for feasibility of machining for me but unless it was something special why not just replace the engine!
To machine and rebuild my engine would be close to £1000 (not much compared to the £2000 14 years ago for the MkII) but against £400 for a 'good' secondhand engine after replacing a few seals, no contest. The worst part will be scraping my engine.
I think the engines are inherently good and poor maintenance is to blame and if tolerances are marginal then that engine is on borrowed time. I will hopefully be picking up my replacement engine tomorrow morning and will then order a few new seals from Marshalls in Lincoln, wish me luck.
Back on the road again!
Well done, old friend.
Not nice work, especially in these current low temperatures. Let us know how the new engine shapes up.
Hi Martec,
As Mike has already said, Well done, I think you have done exceptionally well.
Are you going to retain the old engine for a while?
Oldtimer
Oldtimer
I'll fill up with petrol today for a cake delivery run which should cover 40 or so miles and do the first oil and filter change also top up the jacket water as the air comes out (heater working).
With the two engines opened up I noticed a few differences and confirmed them with comments in the Jaguar specification.
With them in bits there are date markings all over the separate parts, original engine MY2000, replacement 1999 and this engine has 3.0 cast in to the back face of the block. The sumps are identical in shape and dimension, the oil pickup pipe is identical length, but the dipsticks are different.
It appears that up to early 2000 a 'teebar' dipstick was used and the sump held 5.9 ltrs, after this date a ring pull handle was used and the sump held 6.5 ltrs. They raised the oil level by 14mm to get more oil in!!!!!!
From careful measurement when the engine is stopped the oil at maximum is 105mm above the suction (4") and drops by about 1/2" when running, the minimum oil level on the new dipstick is the maximum on the old dipstick.
Not sure what to make of this, but as Oldtimers says I have been beating up an old engine and these crankshaft pumps, although positive displacement pumps still have to pull a minor vacuum to lift the oil initially and keep it flowing.
