ENGINE WON'T START BUT DISPLAY DIALS HAVING "FITS"
Posted: Sat Aug 24, 2013 6:54 pm
by dg4cars
Once again in trouble. For the past few days the interior lights would not switch off when I was driving my year 2000 S Type. They would eventually switch off some time after I parked the car. I didn't pay too much attention and foolishly thought the problem might solve itself. Anyway today the car wouldn't start, thought the battery was dead so put the jump leads on her. When I thought she had got enough juice from the engine of my wife's car I got into the car and turned the key! What happened next was something akin to the car being possessed. All the dashboard dials started going left to right at speed. The external lights started flashing and there was what I can only describe as a ticking sound from the engine bay. Needless to say the engine didn't start.
As mechanics isn't my forte I was afraid to leave the leads on any longer in case I was doing damage.
Can anybody shed any light on what might be going on here.
Derek
(Mikes friend in Ireland :mrgreen: )
Re: ENGINE WON'T START BUT DISPLAY DIALS HAVING "FITS"
Posted: Sun Aug 25, 2013 12:59 pm
I had this at the end of a Northern Day on one occasion due to not fully turning the ignition key fully to the left when leaving the car. It is possible to take the ignition key out of the steering lock whilst still leaving the cd player or radio on. Result, a flat battery.
Trying to start the car produced similar symptoms to the one you described.
I would disconnect the battery and give a controlled recharge using a garage battery charger. Jump starting with only a few minutes donating charge from a donor car will only put a small surface charge of the battery plates. If you S-type battery is old, then it may even resist being recharged if terminal voltage has seriously dropped due to discharge of some sort.
Batteries do not last for ever and so many electrical problems can occur due to a substandard battery. Modern cars are very voltage sensitive and current greedy. Typically if battery terminal voltage drops below 12 volts then the car may be impossible to start. As regards the interior lights being slow to switch off, I`ve not heard of that issue before. Possibly this could be voltage related.
New batteries are sheer joy. Electrical remlins do seem to disappear with a new unit fitted.
Remember batteries can fail with voltage being present but lacking any storeage capacity. They can also fail with storage capacity but low terminal voltage. They can also be classed as failed with a combination of both these symptoms combined.
Anyone else have a further opinion on why or what could otherwise cause the problem described above?
Posted: Sun Aug 25, 2013 5:09 pm
by dg4cars
Thanks Mike,
Knew I could rely on you.
Derek
Posted: Sun Aug 25, 2013 5:46 pm
by jeff1954
Hi Derek
In the hand book it does say when jump starting do not have the donor vehicle engine running
I would do as Mke says and disconnect the battery ect/ect and try again.
Jeff
Posted: Mon Aug 26, 2013 10:43 pm
by Martec
Going back to the original post, there is a reference to the interior lights staying on for a very long time.
From my fiddling about with the door locks, each door contains a switch that tells the Rear Electronic Control Module that it is shut and the interior light will dim quite quickly, if not then the light will stay on for something like 20 minutes until it finally goes out. This switch seems quite robust (unless you tread on it when its opened up), but maybe part of your problem.
As Mike has said a tired battery is not good for the electrics, one car we went to look at had a flat battery and was jump started from a battery pack and a lot of stuff didn't work (A/C) until the voltage came up. Quite heartening to see after all the stories of disaster on multi ECU cars.
