Engine Flush, Yes or No
Gary220262
Has anyone got a definative answer wether an engine flush treatment like Wynns or simular is good or bad. The oil on my 4.0 litre needs changing and with the car being stood for 12 months and not changed for 12 month before (ive only owned it since november) i was thinking of flushing out first but cant seem to find a definitive answer wether it does good or harm to an old engine, any thoughts guys?. Thanks, Gary
GARY
2000 S TYPE 4.0 V8 (for upsetting the wife ! )
2005 Mercedes E270cdi Avantgarde (for commuting and towing caravan)
Re: Engine Flush, Yes or No
OK. The oil needs changing. Probably fairly black if old, oxidised and tired.
If the oil is still little more than brown in colour or better still yellow, then I see no reason for using a flushing additive. If the oil is black, then a couple of oil changes in quick succession should leave you with a fairly clean engine and enough carbon and other contaminates removed in those oil changes to give you the basis for filling with new oil which should remain relatively clean for the next five or six thousand miles.
A black sludge filled engine is another matter. Take a look within the left hand rocker box cover. View via the oil filler cap. Also remove the breather pipes on the drivers side rocker cover to throttle body and examine for excessive black oil sludge. If from this examination engine internals appear clean, then again a flush treatment is in my opinion unnecessary.
Modern part-synthetic or fully synthetic oils are vastly better engineered when compared to products from the 1970`s. At that point oil engineering really stepped up in quality. Mobil 1 synthetic was probably the original base model from which modern oils derive. With better technology and reliability goes the ability of an oil to keep contaminates in suspension and resist destructive sludging and breakdown. ( Within limits of course. Any oil based product will eventually degrade if the ravages of age, heat, pressure, shear, contamination and neglect have been applied. Whatever oil is used, it has a finite life and use after that point is a count down to failure.)
Lets go back to oil oil technology for a moment. I rebuilt a 1935 Austin 10 in 1980. The engine was a full refurbishment with new pistons, bearings and so on. As per the original oil spec, I filled with a "straight" 30w oil, not as was common at the time with a mineral multigrade 20w 50 ash-less dispersant oil. Within 1500 miles, the oil was black and the simple mesh gause filter choked with gunge. 20w 50 provided a longer term solution although oil leaks were more difficult to control.
Moving on again in time, part synthetic and fully synthetic products made an appearance. Both types helped extend service intervals keeping contaminates in suspension, staying visually somewhat cleaner and reducing engine wear as a bonus.
The oils we now use are really chemical designer products. Vastly superior in all respects including reduction of black sludging problems. Black sludging problems are now usually attributable to overheated oil, age and neglect. If those issues are not present, then I personally see no reason for using a flushing product.
Given a sludged engine, then there could be an orguement for using such a product. However, be cautious. Flushing products do indeed release internal sludge and filth from within engine internals. That may not be good as it can lead to the contaminate moving around an engine which might lead to a blockage and cause oil starvation. Even given good filtration, flushing may do more harm that it cures.
Perhaps if you could acertain whether the car has had a good service record, whether the oil is in reasonable condition and the engine free of sludge, we may be able to help you form a more definitive appraisal of whether to use a flushing oil or not. I view such products as only to be used in extreme cases. Given that hopefully your car has been treated to the correct grade of oil and a reasonably regular oil change regime, then I would be surprised to hear that your engine has a dose of the "Black Death"!
Enlighten us more my friend.
Gary220262
Hi Mike, the oil is brown and not black and looks ok ish !, looking under rocker cover etc it doesnt seem too bad at all, the problem i have is that i have no history as such with the car (it was a reposession in 2009 apparently), ive got a receipt for almost £3000 from May 2010 for fitting a replacement engine (supplied by customer with no details / history etc) Changing chains & tensioners, (still got original water pump & thermostat though !) and changing a leaking gearbox seal, re-building and re-filling gearbox all done 11,000 miles ago. Once again am i reading too much into things as i seem to have done with the 308 and looking for problems that aren't there ?. I must add that the car is frightengly fast and makes my old 3.2 V8 seem pedestrian ! gearbox doesn't seem to have any problems and every piece of electrical equipment in the car (of which theres many) works as it should.
I have already got an up-grade water pump and thermostat tower ready to fit when it gets a little warmer and im just really looking to get it ready to use in summer with hopefully no problems
Excuse grammer/punctuation etc as i am a lorry driver not a solicitor !. Cheers, Gary
GARY
All the right signs are there, Gary. A new engine in 2010. Bargain and seriously good news!
Just drop the oil a couple of times and see if it stays clean.
Others may disagree with this. I favour fully synthetic oil as opposed to part synthetic. I`ve found on J44, V8 4 litre, 02 plate, that I use less oil between oil changes and the oil stays cleaner.
Well worth doing the thermostat and water pump. Only five or six 8mm bolts for the pump and three 8mm bolts to access the thermostat. Lift the lower sprung belt tensioner arm, drop the belt off but bend back on itself to check for lateral cracks, drop it down and change the pump and stat. Half hour job at the worst.
Sound like you have a good car there.
Gary220262
Thanks Mike hope your right, i take it theres no difference in changing water pump & thermostat tower on S Type to X308, i did my 308 last summer with advice from yourself and Mester Jenner and it was quite straight forward (apart from the rear nuts on thermostat tower). There looks to be less room to do job, must have shoe horned V8 engine into S type !. Thanks, Gary
GARY
No problem with space at the front of an S-type V8 for tower or thermostat changes.
You do however need an 85-90 degree 8mm bent spanner to unscrew the rear tower bolts. That avoids lifting the inlet manifold plastic banana bunch unit.
The inlet manifold development cost Jaguar over £1m. Nota lotta people know that.
