I've seen references to this before and I thought it was on this forum but can't find it in 'engine' or 'electrics' or using 'search'.
Either way we went out to our usual lunch place and on the way back this massage flashed at us several times with the amber light.
Thinking back when I had replaced the plugs and coils and then cleaned the throttle body with a fine brush, reconnected the battery it fired first time but went up to 1500 revs and slowly returned to about 700. I have since noticed that it does this on each start up and as I change gear (going up the box)the revs don't immediately drop.
I've often seen two faults appear at the same time so not assuming that all the symtoms point to one fault!!!!
I'm thinking,
Did I break a wire when refitting the terminal plugs?
Is the throttle body not initially closing for some reason (fly by wire)?
Is the air bypass valve (can't remember what it is called) sticking now?
Never touched the MAF sensor so not that.
Even though I carefully cleaned the manifold seals when refitting it, are they leaking, but it returns to 700 rpm?
Am I totally in the wrong field?
Advise and suggestions gratefully received.
I had previously provisionally agreed to see my MOT man tomorrow to check the suspension so hopefully to also check the emmisions.
PS I have been expecting faults to appear and not surprised.
'Failsafe engine mode'
Re: 'Failsafe engine mode'
Hello Brian,
If you scroll this page down, just below "post reply" you will see "board index". Click on that, then scroll to S-type, then click on engine, electrics or what ever section you wish to browse.
The big multiplug on the throttle body can cause problems. Make sure the contacts and pins on the throttle and plug are clear of corrosion. Make sure the plug is pushed fully in. The clip arrangement is quite difficult to un-clip but relocating is far easier than unplugging.
These throttle body connections are VERY delicate. Avoid any sideways force as it is exceptionally easy to inadvertently break the connections within the throttle socket and the TAC module within. A couple of years ago I wrote an article about throttle failure in our magazine. I found that a previous owner maintenance session had broken the multiplug securing clip and ham fisted removal of the plug from the throttle socket had broken a connection within the throttle body itself. The throttle body is built as a factory unit and the only part that is user replaceable is the throttle plate position potentiometer on one end of the throttle plate spindle.
I issue this warning about the delicacy of that multiplug and socket as a new unit will set you back £1400 as a new item or a good £500 or so if reconditioned by BBA Reman in Rochester. My throttle body was damaged to an extent that those were my only two options commercially. Eventually I sourced a second had throttle from eBay. I was dead lucky as it came to me for £20 including postage. It fitted straight to the car with the only extra cost being a genuine gasket only available from Jaguar.
My broken throttle used to drop into restricted performance or limp home and would indeed also exhibit similar symptoms to the ones you describe.
A couple of other pointers also. The throttle pedal can go duff occasionally. That is a fly by wire unit linked to the throttle by way of the big issue multiplug described above.
Note also that there is also an air assist valve near the throttle body which again has a small plug and socket attached. Removing the plug whilst the engine is running should case the engine speed to alter. If it does not, you could suspect the connection or perhaps the sliding ported piston within. That valve is held on by two bolts and can be removed to check that it is not sticking. Be prepared to make a new gasket.
Also check to see that the breather tubes from the engine rocker cover to the inlet trunking are sealing correctly. A little WD40 will lubricate the o-rings on the fittings.
V6 cars are prone to rubber elbow air pipe crush and split after high mileage. These should be changed each time plug changes are carried out. They are not expensive but are only accessible when the inlet manifold is off for plug changes. Check for a whistling sound around the rear of the engine. That can spoil engine idle speed.
The previous V6 I ran and now and the V8 I have, both have similar throttle bodies. The only difference is the anti frost coolant hose pipe system. Servicing the throttle body is the same on both models. Check to see all grunge has been gently removed from the throttle bore and throttle plate and that the movement is fast and smooth. Any ratcheting of the plate should be investigated. In my experience it is normal for the revs to rise on start up then drop back to a normal idle. Serious drop off leading to stalling or sticking throttle when driving obviously requires further investigation.
See how you get on with these pointers.
Again Thanks Mike for the information above.
I went to see my local MOT man and asked him to have a good look, and from the U tube video to check all the possible suspension faults. None of the bushes warranted an advisary and the emmisions were very low CO zero and the hydrocarbons a max. of 25. I was told to go away and enjoy it.
A young friend who makes and sells his own ECU's (one running EFI on our Marina and one running switchable ignition maps on the MkII) used an OBDII sensor and found all 4 Lambda's and both catalitic converters OK but one is a bit 'lazy'. Both throttle pot and idle air valve read as OK, so he suggested putting more miles on it as I may have washed some crud into the throttle pot and it will settle down.
Two interesting pieces of information, the engine ECU will learn the revs for start up after the battery is reconnected which will affect a fall back settings ie after gear changing. Or I can disconnect the battery and allow the start up revs to adjust again, also there is often more than one reastat/stepper motor in the throttle pot so if one is corrupted it can carry on on another but give a fault code.
There are no OBD recognised fault codes stored but possibly Jaguar fault codes.
Two people have told me to just drive it so I can see a few days away coming up! so far so good, and learning all the time.
