I wonder if anyone has experience of oil temperature sensor issues on 4 litre V8 models.
I`ve bought a ELM327 OBD/usb car to laptop interface link lead and software package for a humble £10 and have managed to get it to function on an old Dell 1300 with 32 bit XP installed. Have to laugh. That old heap has a 37Gb hard drive and cost me an arm and a leg eight years ago. However a new battery was just £23 from ebay and has the old banger going again very nicely. The diagnostic program appears to be rather more successful on this old Dell than another much newer laptop with 64 bit 7 installed. It doesn`t seem to want to play at all. Paul S thinks there may be a compatibility issue to solve there.
So I`ve managed to get some functionality this evening from the Easy OBD package now on the steam powered Dell. The programme is telling me that the oil temperature sensor has a range or performance issue. PO196 is the fault code shown. Has anyone else ever had to replace such a sensor through similar fault code flag ups?
Not having had to get under J44 to deal with low down issues before, I am assuming the sensor is probably adjacent to the oil pressure sender/sensor which I seem to recall is mounted in the area of the oil filter and its mounting. Can anyone confirm or give any other useful advice please?
Certainly interesting to see various real time perimeters ticking away on the laptop screen tonight. Quite a gathering of yachties clustered around the wezzing laptop as I sat on a keel block and fumbled my way around the computer in the yard this evening. I was "Mr Magic" and people thought I knew what I was doing!
V8 4 litre oil temperature sensor. S, X308, XK8 models.
Re: V8 4 litre oil temperature sensor. S, X308, XK8 models.
Mike,
You can also get a P0196 when you have engine operating temp problems. This can cause a confusion in the oil temp thermistor. The code may be hangup from the engine coolant temp sensor problems that you had recently.
Clear the code out and wait to see if it comes back again. Don't go changing the oil temp sensor just because the code happens to be in the system at the moment.
Thanks Paul,
I did in fact manage to clear codes down last night but this particular code persisted. More investigation needed.
