I removed plenty of part around the engine because because I am working on secondary tensioner, I would like to take the opportunity to change the accesory belt.
I didn't find in the BB the procedure to remove it.
Even if the indication in the tensioner is in a middle saying that the belt is ok, the belt is the 2001 original one and it could be safe to replace it....
Thanks for your information,
Accesory belt
richardtoulouse
Richard
french guy with some English cars in France
XJS 3.6 & S type V8 4.0
Re: Accesory belt
to remove the belt you have to use a long bar and socket on the tensioner pulley bolt, move the bolt to loosen the tensioner and slip off the accessory belt , it will fall away from the rest of the pulleys ,
replacement is as easy ,
Re: Accesory belt
Richard,
You can read about belt changing in this post.
http://www.jec.org.uk/forums/viewtopic.php?f=201&t=4685
You should change your drive belt if it is showing signs of wear for example cracks or splits. You will see a picture of the belt I removed from my car at 76,000. Also you will see the modified new 4.2 water pump which I also suggest you upgrade your car to have. The early type pumps can leak coolant and loose blades on the water pump impeller. Neville Anderson will be the man to talk to for the best price.
